It is currently Sat Aug 16, 2025 1:34 am
 Post subject: Tachometer wiring
PostPosted: Tue Feb 17, 2009 4:27 pm
Hey guys,
Just bought a tacho and needed some advice on the wiring, i can do it sweet but then it says "green wire to RPM signal wire" well i don't have an rpm signal wire, it says to not put it to any positive terminal in the car so i was wondering should i put it to the negative terminal on the coil? or where in mini's with 3 gauge clusters with a tacho does the rpm signal wire come from?
Cheers Jarred
PostPosted: Tue Feb 17, 2009 4:39 pm
Tomboss Breweros
Thats right, put the wire to the - on the coil.
On a 3 guage the signal wire is on the rh end of the cluster, white with a color trace.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Feb 17, 2009 8:01 pm
Thanks for the help mate :D
Users browsing this forum: No registered users and 117 guests
