It is currently Sat Aug 02, 2025 12:54 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 20, 2009 7:00 pm
I'm still shocked by his Mechanics so called remedy :shock:
Wouldn't you try and find the actual issue rather than apply a silly band aid solution that makes no sense anyway.
Dicko
PostPosted: Fri Feb 20, 2009 7:43 pm
ok fellas he found the problem and didnt need to add a ballister resister or what ever it is he had allready tried a new condensor early on. it was the brown wire that comes off the solinoid to the fuse box was not on properly and was just touching the wire down to the coil which was giving it too much voltage. so he fixed it and my car goes really well am very happy with it. :D thanks for all you help fellas and advice is very much appreciated
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
