It is currently Sun Jul 27, 2025 11:20 pm
 Post subject: Cleaning vinyl seats?
PostPosted: Fri Feb 20, 2009 12:35 pm
Milatsmadmini
Spray and wipe is going alright... a little slow though
What would everyone suggest?
PostPosted: Fri Feb 20, 2009 12:37 pm
Tomboss Breweros
Go to a auto store, in the polishing section find the Autosol metal polish, near that you should find Autosol vynil cleaner in a blue tube. Works really good on plastic too.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Feb 20, 2009 12:53 pm
Meguireres Dash cleaner its a foam, works brililantly at removing scum and marks off interior vynils
PostPosted: Fri Feb 20, 2009 1:52 pm
try thinners it seems to work well.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Fri Feb 20, 2009 4:11 pm
Soap and water. You are trying to remove dirt, you are not trying to hurt the vinyl.
Most trimmers recommended using soap and water. A scrubbing brush will help as long as it is not too rough, I use a nail brush but some people will use a toothbrush for the seams.
Thinners, chemicals and a lot of other cleaning products will hurt the vinyl.
PostPosted: Fri Feb 20, 2009 4:14 pm
CRC So Easy Tire foam works quite well but makes it rather slippery.
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Fri Feb 20, 2009 6:30 pm
I'm Bert , where's Ernie
Do NOT use thinners as morris has said, it has a tendancy to 'split' the colours in the vinyl, effectively making them run. soap and water, or go to the local supercrap and get a hold of some of the meguiars, or armor all vinyl cleaner, talk to lachie (caponix), i got him to use the same stuff and should see his results 8) :P
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Fri Feb 20, 2009 7:18 pm
Go to the supermarket and get some Gumption cleaner paste - in the household cleaning section.
It works a treat.
Julie.............
PostPosted: Fri Feb 20, 2009 7:46 pm
ok maybe you shouldnt use thinners...... :?
1970 mini k
1975 leyland
PostPosted: Fri Feb 20, 2009 7:50 pm
sunlight soap and warm water
PostPosted: Fri Feb 20, 2009 7:59 pm
Spray and Wipe with a small scrubbing brush. Once dry then spray with Armorall to return some moisture into the vinyl.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Feb 20, 2009 8:05 pm
Nothing will return moisture to vinyl. :cry:
It is a myth to sell expensive cleaning products.
PostPosted: Fri Feb 20, 2009 8:23 pm
.....and if you've worked in the motor trade for dealers and replaced as many dash tops as I have you wouldn't use Armourall on anything.
PostPosted: Sun Feb 22, 2009 10:37 am
thats interesting, i used amourall on my dash once, which then caused it o slowly warp... i think it started the process.
on the subject, i was going to post a new thread but i'll just hijack instead (insert rude emoticon) how about cleaning seats with dot-cloth bits? i took my seat covers off the other day and my chairs are FILTHY!!!
78 Leyland Mini - Prince
PostPosted: Sun Feb 22, 2009 3:39 pm
Meguires doesnt leave the oily residue, just lifts the dirt off
