It is currently Thu Jul 24, 2025 12:40 am
PostPosted: Tue Feb 24, 2009 3:13 pm
Its at Lemon Tree Passage in the New Castle area.
Im not sure of anyone in that area, but would appreciate somebody to look at it.
PostPosted: Tue Feb 24, 2009 3:14 pm
Here is a bigger pic of the engine
PostPosted: Tue Feb 24, 2009 3:43 pm
Give Graham a PM , http://www.ausmini.com/forums/profile.p ... file&u=337 , nice , trustworthy guy who's sort of in the area (well , a bit further south anyway) and will possibly be able to check it or be able to tell you someone else who will be able to check it without trying to get it themselves if it's a bargain .
PostPosted: Tue Feb 24, 2009 3:50 pm
I could have a look for you, LTP is about 15 min's from me.
PM me details, yours and/or theirs and I'll see what I can do. And fear not, I don't have any spare readies so won't steal it from you if its a bargain.
Dicko.
PostPosted: Tue Feb 24, 2009 5:34 pm
its a 1275 people. look at the extra studs in the head, the angle of the heater tap outlet and the welsh plugs. S block & Mk 1 S head.
Have a Nice Day.
PostPosted: Tue Feb 24, 2009 5:40 pm
No doubt! It's just the legal implications if the engine is stamped with a 998 engine number we're worried about.
PostPosted: Tue Feb 24, 2009 6:54 pm
Dicko.
PM sent
PostPosted: Wed Feb 25, 2009 1:12 pm
Hi there, I can go if Dicko can't, he is closer than me though!
Cheers! :P
Graham
Sir Alec! we are not worthy!
PostPosted: Thu Feb 26, 2009 7:28 am
I went and had a look last night, and though I know very little about 1275's (all of my Mini's have been small bores) I'll post what I noted.
EDIT - Added items in Blue
    As noted has the extra Stud and room between Rocker cover and Thermo Housing.
    The Welsh Plugs are Cup Type, not Convex.
    It has Side/Tappet Covers.
    The Engine No was as listed.
    It is a 1962 850
    It is currently registered in NSW (till September I think) and has been for about 5 years going by th AA ** ** Rego.
    It has had a Nissan/Hitachi Distributor Fitted
    It goes like the clappers :shock:
    It has a fairly hefty Cam, but if you keep it up on the power band, woo-hoo.
    The Gearbox was the nicest Mini Box I have ever used, short throw, precise, very nice. :shock: :) :D 8)
    Yes, I took it for a nice "test drive" at the encouragement of the owner.
    It has Minifin Alloy Drums on Rear.
    Cooper S Disk Brakes at Front.
    Adjustable Lower Arms.
    Doesn't have Hi-Lo's
    The Drivers seat is a bit loose, will need to check the mounts
    It appears to be pretty well rust free, small ding in Drivers Door, there is a small split in the passenger floor, but seems solid around it.
    There is paint cracking off the boot around/under the No Plate Flap
Might have forgotten some bits and pieces, but all in all seems like a nice car and worth a look. As stated it is registered in NSW so would have had to go through an Identity Check process, so not sure what the implications of the Engine No would be in other states. In NSW it has already been accepted though.
PostPosted: Thu Feb 26, 2009 7:11 pm
Awesome thanks for the info and most importantly for your time.
Im currently looking into flights to come down.
Jake
