It is currently Thu Aug 07, 2025 11:30 pm
 Post subject: what oil should i use
PostPosted: Tue Mar 03, 2009 1:27 pm
finally got mini just doing a service its got straight cut gears in the box what oil should i use?
PostPosted: Tue Mar 03, 2009 1:29 pm
Tomboss Breweros
If it leaks, cheap 20w50
If it doesn't leak, good 20w50 :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Mar 03, 2009 2:00 pm
As recommended by 'Dr Mini in Aust' and others, I use K-Mart brand motorpro KMX 20W-50. Under $20- for 6 litres and I change oil and filter every 2000 miles. I also use a rare earth magnet on the filter to catch metal fragments before they reach the oil plug magnet. That is up to you though.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Tue Mar 03, 2009 2:36 pm
Hey Flute, where do you get those rare earth magnets and where do you attach it?
thanks, bam.
PostPosted: Tue Mar 03, 2009 3:00 pm
http://www.amfmagnetics.com.au/neodymiu ... iscs_large
I use the 25dia x 10 ones, sit it on the side of the spin-on filter down the bottom where the finger grips are.
It'll stay there..
I fit 2. :wink:
PostPosted: Tue Mar 03, 2009 4:39 pm
I've always used a couple of old hard drive magnets.. got an old hard drive? pull it apart and there's likely to be something suitable in there...
tim
PostPosted: Tue Mar 03, 2009 6:00 pm
Geez, it's almost like the spooky stuff Brock was into.
However, if the good Doctor does it, who am I to nay say?
Thanks guys.
PostPosted: Tue Mar 03, 2009 6:14 pm
I suggest you just put one on and run it, then cut the can up after you have run it 3000 miles. Check out all the fine junk in there. :shock: :P
Anything under about 50 or 60 microns size doesn't get caught by the filter. It just goes, round, and round, and round...
Sure, the magnet only gets the steel and iron (ie magnetic), but they are the hard bits that do most damage.
ps. I now get bugger all on the sump plug magnet.. as it gets caught by the filter magnet first.:mrgreen:
PostPosted: Tue Mar 03, 2009 6:23 pm
Thanks Doc, will do. With all the $'s spent on the moneypit, any nasties I can keep out is good for me.
Just an aside, formerly being an organ donor, i.e. I rode motorbikes and lost some, why ain't premium bike oils good for these engines ? Seems an engine and g'box sharing the same oil would be appropriate. What am I missing here? bam.
PostPosted: Tue Mar 03, 2009 7:45 pm
This space for rent
They are, they're just bloody expensive.. especially when a Mini takes double? that of a bike..
[quote="bamnfi"]Hey Flute, where do you get those rare earth magnets and where do you attach it?
Didn't mean to hijack the oil thread with the magnets but here is the link to the magnet discussion. I got the big one the doc recommended. $34- delivered in the mail. It will never fall off.
http://www.ausmini.com/forums/viewtopic ... highlight=
Member: VMCI #2474
PostPosted: Wed Mar 04, 2009 4:49 pm
Thanks for the info guys...
Finally got home with the Mini. Its a long drive from Newcastle to Gladstone, especially when the car does 4350rpm@100kms (Navman GPS)so i spent most of the time doing 90kms, didnt matter so much in NSW as 1/2 the way was road works.
I will post pics in the owners gallery when i get a chance.
PostPosted: Wed Mar 04, 2009 4:55 pm
ginger ninja
ginger ninja
4350rpm doesnt seem too high, Cherry does over 4000rpm at that speed but then again I dont know what kind of mini you bought! Mine is a 998 and loves the revs :P
sports850 wrote:
