It is currently Wed Jul 23, 2025 12:40 pm
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Tue Mar 03, 2009 9:13 am
nothing wrong with a good small bore :D
pull your engine down and see what's wrong with it. it's not common to need a whole new engine unless the problems you're having are recurring, or some part (or parts :shock:) have come loose and caused internal damage
78 Leyland Mini - Prince
PostPosted: Tue Mar 03, 2009 5:10 pm
The engine is shagged...from all the highway driving I do :oops:
It's coming out this weekend and will be looked at in detail to find the source.
PostPosted: Tue Mar 03, 2009 5:31 pm
Think about a taller diff whilst the unit is apart :idea: :D
PostPosted: Tue Mar 03, 2009 5:46 pm
I have a fairly 'high' diff at the moment...my revs sit at 3500rpm doing 100km/h. I've been told that's pretty good :)
PostPosted: Tue Mar 03, 2009 5:48 pm
Not bad....but if you go larger (1275) you might also be able go up another notch :D
PostPosted: Tue Mar 03, 2009 6:00 pm
PostPosted: Tue Mar 03, 2009 6:11 pm
how long had the trooper been going for ??
sorry to hear ur bad news. i've going easy as on me 998,, not sure how long my trooper status is going to last.
GL with it all.
fiji
PostPosted: Tue Mar 03, 2009 6:27 pm
The engine has lasted 33 years :P
PostPosted: Sun Mar 08, 2009 5:18 pm
More to upload
PostPosted: Mon Mar 09, 2009 9:19 pm
All four pistons have cracked rings, and one piston was actaully damaged in the process of these rings cracking.
I have photos to show, they're taking forever to upload.
PostPosted: Mon Mar 09, 2009 9:27 pm
like i said in the txts i sent you, i'd dare say the engine must have been overheated at some stage, that would cause the rings to crack, aside from being cheap quality (if so) or old age, but most likely over heating I'd say, because you never seemed to blow any smoke out the back, not like Bluey, but I do know whats causing that so thats ok, lol.
Keep us updated :)
PostPosted: Mon Mar 09, 2009 9:29 pm
Not it's never overheated.
The engineer said that the distributor was out of time a little which was causing the pistons to fire slightly earlier than they should.
PostPosted: Mon Mar 09, 2009 9:39 pm
PostPosted: Mon Mar 09, 2009 9:44 pm
This space for rent
Yep, she's stuffed alright :shock:
PostPosted: Mon Mar 09, 2009 9:46 pm
Sooo very lucky it didn't damage the bore :shock:
Users browsing this forum: 1071 S and 79 guests
