It is currently Fri Jul 25, 2025 11:43 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Mar 02, 2009 10:39 pm
the engine is probably buggered
PostPosted: Mon Mar 02, 2009 10:53 pm
I is a mookenik
i was thinking the same thing... its pretty smokey and in 4th gear doing around 80km/h u can smell exhurst fumes in the cabin....
PostPosted: Tue Mar 03, 2009 6:42 am
Joe, I have a good 1098 (998 stroker) on a rodchange box out of Barney, if you need one.
It went well and used bugger-all oil when it was in the car. 8)
PostPosted: Tue Mar 03, 2009 8:27 am
ginger ninja
ginger ninja
minor details :lol: Mine's smokey all the time!
sports850 wrote:
 Post subject: Re: vibration
PostPosted: Tue Mar 03, 2009 8:44 am
ok ive owned the new van for a day now and already i have found that it has a pretty bad vibration when u accelerate... when u let it roll freely and in gear it doesnt vibrate but soon as u hit the accelerator it shakes and vibrates
any ideas?
:P The owner/driver :?: :lol: :lol: :lol:
PostPosted: Tue Mar 03, 2009 9:56 am
everything described in this thread sounds like normal mini'ing to me!
tim
PostPosted: Tue Mar 03, 2009 10:22 am
I was just about to say that... what type of vibration are we talking about? violent shaking or constant humming vibration?
PostPosted: Tue Mar 03, 2009 12:45 pm
Lillee wrote:
I was just about to say that... what type of vibration are we talking about? violent shaking (apparently thats the other one he owns, ask BIAM)or constant humming vibration?
:P he probably put new batteries in it and is working at its optimum performance :!: :lol: :lol: :lol:
PostPosted: Tue Mar 03, 2009 6:30 pm
what about the nut behind the wheel?
PostPosted: Tue Mar 03, 2009 8:25 pm
I is a mookenik
... ok ive been thinking about it while driving to work... now if it was the uni joints wouldnt they vibrated on the motor all the time not just when im accelerating? and the motor is not to bad now :D. just needed a good service. the unis have been rubbing on the gearbox though because it has scuff marks... so possible steady bars?
PostPosted: Tue Mar 03, 2009 8:31 pm
If the uni joints are rubbing the gearbox of if the U-bolts on the unis are rubbing against the yokes..... park the car.
PostPosted: Tue Mar 03, 2009 8:36 pm
I is a mookenik
yeah i know but i need the car to get to work... ill just have to change them when im at work tomorrow.
PostPosted: Tue Mar 03, 2009 8:41 pm
Be very carefull with rubber unis. It is quite easy to knock a hole in the gearbox.
When replacing rubber unis joints you do not do up the nylock nuts on the u-bolts very tight. If you do them up tight it will stuff the joint in a couple of weeks.
It used to be possible to get a better replacement uni joint....
I have these in my 1100, but they are out of production. :cry:
PostPosted: Tue Mar 03, 2009 8:44 pm
I is a mookenik
ill have to do it tomorrow then. once u have undone the u-bolts can u just pull them out with out removing the shafts?
PostPosted: Tue Mar 03, 2009 8:48 pm
You can squeeze them out with a lever or you can undo the bottom ball joint to get more room.
Users browsing this forum: No registered users and 117 guests
