It is currently Sat Aug 02, 2025 9:05 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: How Fast?
PostPosted: Fri Mar 06, 2009 9:07 am
Now that I have added an extra 300 mls of oil to my Moke - what impact will it have on performance?
and if I dont get answers I want I will post a poll where I will whine and carry on about how unfair everybody is :P
PostPosted: Fri Mar 06, 2009 9:13 am
Get ****ed!
The 300ml will be sitting on your driveway by now.
PostPosted: Fri Mar 06, 2009 9:15 am
I think the weight of the oil will be offset by the increased viscosity of the oil.
You wil have a nett gain of zero, so the moke will be the same speed even though
it has more power at the flywheel.
:D
PostPosted: Fri Mar 06, 2009 9:16 am
On the mokes performance or the oils performance ? With the extra weight of the oil it will force a further 500mls of oil onto your garage floor at a greater speed than if you hadn't added the 300mls .
PostPosted: Fri Mar 06, 2009 9:17 am
:D
when I was changing the clutch I accidently scrached the flywheel so now its lightened!!! if you factor this in does change how fast it goes?
PostPosted: Fri Mar 06, 2009 9:30 am
I agree with the eloquent awdmoke.
PostPosted: Fri Mar 06, 2009 9:36 am
Where did you put the oil? Putting the oil in different places will have a different effect on speed.
PostPosted: Fri Mar 06, 2009 10:52 am
It is in a container in the back
PostPosted: Fri Mar 06, 2009 10:58 am
I think you must change your user name first, then start the poll
PostPosted: Fri Mar 06, 2009 11:32 am
You need a clear understanding of the oil flow in an A-Series engine.
This schematic might help:
PostPosted: Fri Mar 06, 2009 12:12 pm
that piccy is to big can u Make it smaller so it will fit in my 15' screen plz. yes 300ml of oil will make u go faster but depends on how heavy ur foot is and how slow ur gear changes are when u hear those valve bouncing change gears. i was told all this from my Transformer radio cabbage.
PostPosted: Fri Mar 06, 2009 12:35 pm
Tomboss Breweros
Clearley it will be slower - more work for the pump, and more oil for the gears to turn through will make a massive drag in the driveline. You should drain some out.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Mar 06, 2009 12:41 pm
If I drain a little bit out it will go a bit faster, so if I drain all of it out it should fly?
PostPosted: Fri Mar 06, 2009 12:45 pm
You'll need wings to make it fly.
Maybe replace the oil with Red Bull? :D
PostPosted: Fri Mar 06, 2009 12:48 pm
I stripped a 1275 motor & S box once that had NO oil in, the owner let it get low because it had Bardahl or Nulon or some other additive, and he had seen how an Alfa GTV made it to Melbourne and back with NO oil (true!). So, he reckoned `she'll be right mate'. :shock: It wasn't...
The crank needed .020" off to clean up, and the 1st motion shaft and cluster gear I threw away because the needle rollers had worn through the hardening insde them. Ditto the gearbox mainshaft.
I currently have two pretty good 1275 motors here that were run low on oil, both need the crankpins ground due to serious wear.
So, don't let that oilz get too low, people! :P
Users browsing this forum: watsupskip and 83 guests
