It is currently Sun Aug 03, 2025 12:26 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Mar 06, 2009 12:52 pm
Tomboss Breweros
blokeinamoke wrote:
If I drain a little bit out it will go a bit faster, so if I drain all of it out it should fly?
Yeah, just like coolant, that makes unnececary drag on the water pump that you don't need :roll:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Mar 06, 2009 1:02 pm
So if I drain all the coolant and all the oil will my 998 A-series be quicker than a 1275 BMW headed twinkie?
If so I have solved Spaceboys conundrum :!: :!:
PostPosted: Fri Mar 06, 2009 1:08 pm
If you remove oil from the container in the back it will go faster.
PostPosted: Fri Mar 06, 2009 1:12 pm
how much faster?
PostPosted: Fri Mar 06, 2009 1:15 pm
Tomboss Breweros
That flamable liquid that you put in the side creates excessive weight, get rid of that too 8)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Mar 06, 2009 1:18 pm
blokeinamoke wrote:
how much faster?
The same amount as if you lost .3kg body fat.
PostPosted: Fri Mar 06, 2009 1:20 pm
poeee wrote:
blokeinamoke wrote:
how much faster?
or got a haircut
PostPosted: Fri Mar 06, 2009 1:41 pm
:shock: You have 1/3 of a kg of fat in your hair :?
PostPosted: Fri Mar 06, 2009 1:42 pm
mokes are ugly :P
PostPosted: Fri Mar 06, 2009 2:13 pm
maybe near ?
PostPosted: Fri Mar 06, 2009 8:48 pm
hey it really is all about the "power to weight Ratio" right,,, that`s what accelleration is all about right??? the lighter the car the faster it accellerates yeah???,,, It`s just simply physics,,, no need for any more technical jargon than natures own forces at it`s best,,,well the road wheels & tyres are pretty dam heavy,,, so get rid of all of those too yeah? surely it will go much faster then right?
PostPosted: Fri Mar 06, 2009 9:30 pm
Tomboss Breweros
Damn straight, all that metal in the body is doing nothing but slowing you down.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Mar 06, 2009 9:55 pm
not to mention the wind drag
& also the brakes,,, dam things only slow you down too,,, get rid of those as well ;-)
PostPosted: Fri Mar 06, 2009 10:21 pm
If you are really worried about the effect of excess weight on performance, then have a BIG crap every time before you drive the thing. :)
the only time to get worried is when the white guide posts along the highway start to look like a white picket fence. In a moke THEN I would get worried :shock:
www.minisprintgt.com
PostPosted: Sat Mar 07, 2009 6:44 am
I usually have one while I am driving - the brakes are that bad
