It is currently Fri Jul 25, 2025 11:47 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sat Mar 07, 2009 5:20 pm
tinymorris1969 wrote:
dont say that... :cry:
Well regarding that line bore job Doc mentions, it sounds like it's coming just not on the motor!
Sounds like swapping the motors over, then diagnosing the old motor is the best way Joe.
KB
PostPosted: Sat Mar 07, 2009 8:14 pm
the cheapest solution to your problem is to get a bus pass so you can get to work hassle free.
PostPosted: Sat Mar 07, 2009 11:52 pm
well i want to put tinys old motor in the van but if mum finds out that the vans motor is rooted shes gonna flip chips!!.
just tell her you want to give the vans motor a clean and paint
PostPosted: Sun Mar 08, 2009 9:13 am
Internally!
PostPosted: Sun Mar 08, 2009 10:51 am
Get tiny's motor out and cleaned ready and painted. Then it should take you no more than a day to do the swap. Not hard to do. Then pull down the vans motor, and diagnose the problem from there. At the moment there is a lot of speculation as to what the problem is. You will not no for sure until the motor is pulled down.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
