It is currently Tue Jul 22, 2025 10:31 am
 Post subject: 13 inch wheel problem
PostPosted: Sat Mar 07, 2009 5:59 pm
i have got a little bit of a problem i have 13 x 7 inch rims with sportspack arches and now that i have put metro turbo brakes on the car the tyres rub on the flares any ideas? will ajustable camber fix this?
PostPosted: Sat Mar 07, 2009 7:28 pm
Pics :?:
PostPosted: Sat Mar 07, 2009 7:31 pm
metro turbo brakes run a wider track - the drive flanges are substantially thicker than for standard disk brakes. So your wheels are further out, you have more scrub radius, so the wheels move further forward and back, so hit on the flares. Adjustable arms might fix it a little, but more likely you're just going to have to jack up your suspension
edit: or get rid of the huge wheels ;)
PostPosted: Sat Mar 07, 2009 7:34 pm
I agree with the above idear.
lifting the car up will help.
im running metro brakes but ive got 13x6 and i had huge rubbing problems
i just cut lots of metal away witch was covered buy the arches anyway...fixed my problem.i was not running sport pack arches though so i dont no if its possible to cut excess metal ??
great brakes....i love mine...
PostPosted: Sat Mar 07, 2009 7:49 pm
ill take pics tommorrow it doesnt hit the metal as yet because the car is not on the road might have to jack it up a fair way then unfortunetly
PostPosted: Sat Mar 07, 2009 10:23 pm
Trim or move your flares. Or both.
PostPosted: Sun Mar 08, 2009 1:51 pm
and now your car is illegal same as mine your wheel track is to wide.
PostPosted: Sun Mar 08, 2009 2:42 pm
?illegal?? so what happens to folk s with this set up if they need to claim insurance? A quick pit stop after the fact and change wheels?
PostPosted: Sun Mar 08, 2009 2:54 pm
There is no insurance on illegal cars. If the insurance company chooses they can cancel your insurance if you have an accident.
It is up to the owner to ensure the car is legal.
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Mar 08, 2009 3:22 pm
OK, I passed the IQ test then.
Which leaves me to woinder whythefeck you would do it :roll:
PostPosted: Sun Mar 08, 2009 3:28 pm
because people believe that because their insurance company knows that it on there it is all good.
not the case, but most people would be lucky to get away with it.
PostPosted: Sun Mar 08, 2009 3:32 pm
steve would regency pull me up on it if the wheels were inside the flares?
I dont have to have an inspection, just an engine no. check..
blokeinamoke wrote:
PostPosted: Sun Mar 08, 2009 3:39 pm
an id inspection isn't actually regency. this is the police side of things.
I have more trouble here than i do with a full compliance and roadworthy at regency.
Having the wheels under the guards doesn't make it legal, but it doesn't draw attention to the car. the more standard the car looks the easier it is.
Or you can do it up on sturt road on wed or thurs.
PostPosted: Sun Mar 08, 2009 6:10 pm
your wheel track should be front 1276 mm rear should be 1236 mm plus 25 mm which is 12.5 mm each side anything over that is totally illegal mine is 100mm over
it is measured from centre of tread to centre of tread.
cheers and good luck
PostPosted: Sun Mar 08, 2009 6:23 pm
That is a good theory as long as you get that chance.
But imagine this scenario... You are driving along at 48kph in a 50 zone when suddenly a little kid runs out between two parked cars and the kid hits the side of your car. The kid falls over backwards and hits it head on the ground. The kid is brain damaged and needs care for the rest of its life. The police at the scene initially say that you are not to blame but when the crash investigators arrive they notice that your car does not meet the roadworthy rules...
Then your third party personal insurance company says that you are not covered...
Then the family of the kid sue you because you were driving an unroadworthy car...
Opens can of worms...
