It is currently Fri Aug 01, 2025 3:58 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: Riddle me this
PostPosted: Sun Mar 08, 2009 2:29 pm
Going around a lh corner the battery retainer broke shorting the battery against the body. The engine died and shower of sparks erupted from the main power lead where it goes through the firewall ( the insulation has work through)
Pull over - resecure the battery and tape up the leap and I am off.
First corner - total brake failure - pedal straight to the floor. A few our fathers later and I managed to stop on what was left of the handbrake and gearbox.
On inspection it appears the body had shorted against the front to rear brake line. Would this melt the master cylinder seals?
There was no fuild lost and the master was full. The pedal was still connected properly.
Any ideas?
PostPosted: Sun Mar 08, 2009 2:50 pm
Lucas brakes no smoke = no brakes
PostPosted: Sun Mar 08, 2009 3:23 pm
I doubt it, current always finds the most efficient way to ground, and the master cylinder seals don't form part of this path.
I would however bleed all the fluid in the lines, as the red hot pipe has boiled the fluid into something less to do with brake fluid.
PostPosted: Sun Mar 08, 2009 3:26 pm
just unlucky i'd say. I wouldn't think they were related.
PostPosted: Sun Mar 08, 2009 3:31 pm
Strange current path however...why would the brake pipe become a conductor?
PostPosted: Sun Mar 08, 2009 3:37 pm
you must have hit that corner like the angry fist of god.
blokeinamoke wrote:
PostPosted: Sun Mar 08, 2009 3:44 pm
shorted to the live body because of the battery shorting out on the body.
However boiled brake fluid in the pipe would leave an air gap and therefore no pedal.
PostPosted: Sun Mar 08, 2009 4:53 pm
Resident Haemorrhoid
Any injuries yet Stephen??
apart from your dry cleaning bill
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Mar 08, 2009 5:07 pm
Tomboss Breweros
Well i dont think the body could become live as such unless the earth has come off, and if that happened there could be no short.
Since the master cyl is bolted to the car it is earthed, and all the brake pipes should be earthed through the master and wheel cyls, there cant be a short in there.
The only way i could see a battery cooking a brake line was if the + terminal hit a brake line.
Sorry but it's not much of an answer for your riddle.
I have had unexplained brake failures twice.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Mar 08, 2009 5:53 pm
How do you explain the arc marks between the body and the brake line ?
and no contact between brake line and terminal
PostPosted: Sun Mar 08, 2009 5:56 pm
Slow-Po
You do know that thing is out to kill you....
PostPosted: Sun Mar 08, 2009 6:06 pm
Tomboss Breweros
Magic
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Mar 08, 2009 6:12 pm
Tomboss Breweros
Stray spark from a lead?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Mar 08, 2009 6:13 pm
Too much of a co-incidence that it happened at the same time.
PostPosted: Sun Mar 08, 2009 6:19 pm
where is your rubber gromit to stop things earthing out and rubbing through. you are a hopeless person that does not deserve a special vehicle and you deserve everything the morris/leyland vehicle dishes out to you
Users browsing this forum: Bing [Bot] and 81 guests
