It is currently Sat Aug 02, 2025 12:11 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Mar 08, 2009 6:20 pm
lil-ute wrote:
blokeinamoke wrote:
How do you explain the arc marks between the body and the brake line ?
and no contact between brake line and terminal
where is your rubber gromit to stop things earthing out and rubbing through. you are a hopeless person that does not deserve a special vehicle and you deserve everything the morris/leyland vehicle dishes out to you
it was there two weeks ago - I will replace it when I this week.
PostPosted: Sun Mar 08, 2009 6:22 pm
you should know better i am txting space boy as we speek
PostPosted: Sun Mar 08, 2009 6:23 pm
I already have - in case he was concerned :wink:
PostPosted: Sun Mar 08, 2009 6:25 pm
It's an odd one... It might be there was simply not enough surface area in the steel section there to shunt away 200-350 amps of current all at once. Or not enough spot welds and clean metal joins. So it shed it off onto anything which conducted.
There probably should be a grommet around the brake line there to stop rubbing, also the current and obvious sparks at that point has eroded the pie or the metal or both. Might need to have that line looked at lest it let go under strong braking.
PostPosted: Sun Mar 08, 2009 6:30 pm
It will be replaced. The grommet was put back when it was rebuilt - but obviously has gone. I will check and replace/refit all the others - just another wake up call from Mr Moke
For some reason the current decided the quickest path to earth was through the brake pipe. These things happen.
My brother had a Ford Galaxie in which the head lights went dim when you lifted your foot off the accelerator and went bright when you put your foot down. This sounds like a voltage regulator problem until you realise that it would do the same thing with the motor switched off!
The earth strap was missing between the body and the engine and the accelerator cable was acting as a variable resistance earth cable. :lol:
PostPosted: Sun Mar 08, 2009 6:37 pm
Tomboss Breweros
I think the moke is haunted.
Have you ran anyone over lately?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Mar 08, 2009 7:04 pm
I wonder if the gromett went missing the same time as the car cover went missing?
PostPosted: Sun Mar 08, 2009 7:06 pm
Tiny's home BBQ :shock: so this is his fault as well :shock:
PostPosted: Sun Mar 08, 2009 7:10 pm
blokeinamoke wrote:
I wonder if the grommet went missing the same time as the car cover went missing?
Could be. :?
I personally think that Tiny was innocent all along, I think it was Captain Spacepants. 8)
PostPosted: Sun Mar 08, 2009 7:15 pm
Could be. :?
You mean Super Spacepants Your being so mean - watch out or we end up with another poll :P
PostPosted: Sun Mar 08, 2009 11:25 pm
speedy wrote:
You do know that thing is out to kill you....
I have been trying to tell him that since he got it on the road, he just won't listen
give us a list of all the bizarre things that happened to you BIAM, starting with the wheel falling off and getting pinched by a taxi driver
PostPosted: Sun Mar 08, 2009 11:46 pm
I have a old friend that let his mate have a drive in his Mk 2 Cooper S years ago, he overcooked it and hit the bank and the car rolled and ended up on its roof. Both the guys had to get out quickly as fuel was leaking into the car and soaking into the headlining and there hair. They got out and were sitting on the side of the road when the boot lid flew open and the car burst into flames. the battery wasnt secured and in the crash, while the car was upside down the battery fell out of its hole, pulled the positive terminal of the cable and then was hanging off the short earth strap with the pos terminal welding itself to the RH petrol tank. the heat from the fire melted the gearbox case. Only the wheels survived and are now used on a race car trailer.
Have a Nice Day.
PostPosted: Mon Mar 09, 2009 7:49 am
this sounds like a biam episode
PostPosted: Mon Mar 09, 2009 11:58 am
lil-ute wrote:
this sounds like a BIAM episode
sure does...
when I crashed my blue one - the right hand fuel tank took the brunt of the impact and split open, but the battery box also shifted over, it pulled the earth strap off the battery... so when I was mostly unconscious and upside down in a pool of fuel, there wasn't a lot of danger of bursting into flames
Users browsing this forum: Barkfast and 85 guests
