It is currently Thu Jul 31, 2025 8:53 am
PostPosted: Mon Mar 09, 2009 5:54 pm
maybe one big one or under the rear bumper?
i've been thinking about it but not sure.
any one with pics done, post them up so we can look!
PostPosted: Mon Mar 09, 2009 5:56 pm
Some clubmans came with them. They just use the indicators. There is a switch on the back of the gearbox.
I have seen others that have a single light mounted either on the boot or under the rear bumper.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Mar 09, 2009 5:57 pm
yeh i got a van.. so no lights on the back just toying with the idea,
see who has done it & if it looked good.
PostPosted: Mon Mar 09, 2009 6:00 pm
Later van lights had twin filament bulb holders in the top and the bottom.
So you just need to connect the wiring ;)
Externally they look the same :)
Matt
PS I have some in the shed i think
PostPosted: Mon Mar 09, 2009 6:03 pm
I'm not sure about the real early mini's, but i thought they all had reverse lights, they are just never hooked up. So that when its in reverse both your rear indicators come on.
If the gearbox is a rod change there will be a switch in the side of the rod change unit and the remote boxes have a switch on the front of the gearbox. I'm not sure if all of the remote boxes had them though
PostPosted: Mon Mar 09, 2009 6:06 pm
intresting i got a rover 1275 with a rod gearbox so that would have the reverse thing in it?
it is a 1964 traveler.
i've never heard of this before hehe intresting! the local mini man was tellling me i had to get new lights & cut the back of my car to make them fit.
pfft what a joke as if you would.
i wonder if my car has them unwired
PostPosted: Mon Mar 09, 2009 6:13 pm
Roundies-
Only Police Minis and later Mk2s had reversing lights in the blinkers. The bulb holders were twin filament not single, they used 21W/21W bulbs.
Clubbies-
All Clubbies had em, same setup.
I'm sure we could add reversing lights to early Mini rear blinkers (using single filament bulbs) by adding a diode in the lines.
Last edited by drmini in aust on Mon Mar 09, 2009 7:45 pm, edited 1 time in total.
PostPosted: Mon Mar 09, 2009 6:15 pm
It is quite easy to fit reversing lights to any Mini.
If it is a rod change the switch will be on the gearchange under the car.
You don't need to use a double filament globe holder, you can just hook the reversing light to the rear blinker and fit a diode to the blinker wire to stop the front blinkers from coming on with the reversing lights.
PostPosted: Mon Mar 09, 2009 6:48 pm
if i hook up both indicators they might think i'm turning both ways :lol:
anyways.. that dual bulb thing seems intresting.
so it just shows a yellow light or red?
PostPosted: Mon Mar 09, 2009 6:54 pm
orange :o
PostPosted: Mon Mar 09, 2009 8:59 pm
On my 850 the reverse lights are on either side of the number plate and they work very well.
When I first got the car it had a small spot/flood light under the rear bumper aswell, (that's the only picture I have available now).
Either one works well and if it's tucked up under the bumper it doesn't stand out too bad.
 Post subject: reversing lights
PostPosted: Mon Mar 09, 2009 9:18 pm
When it gets really dark, I use the brake lights as my reversing lights. Top of my shoe lightly on the brake and my heel on the accelerator...
But yeah, I have always wanted to fit extra bright reversing lights, but never found a visually appealling solution.
Michael Jones
Minis In The Gong
[email protected]
PostPosted: Mon Mar 09, 2009 9:27 pm
nice one mate.. where did you get them from the look perfect..
PostPosted: Mon Mar 09, 2009 9:34 pm
I can't remember, try your local auto shops and maybe even look at some LED bar set ups, they will fit under the rear bumper really well.
PostPosted: Mon Mar 09, 2009 9:43 pm
the side ones look better..
ill look for some small square ones.
Users browsing this forum: Bing [Bot] and 78 guests
