It is currently Sat Jul 26, 2025 12:10 am
 Post subject: boiling fuelbowl
PostPosted: Mon Mar 09, 2009 6:18 pm
Dads mini has been having a couple of poblems today..
We were having a look at the su and noticed that the fuel in the [edit, not dashpot] fuel bowl was boiling..(this was after it was given a fang around the streets)
It is a standard 1 1/4 su on 1litre motor
What causes it to boil?
PostPosted: Mon Mar 09, 2009 6:26 pm
Heat, probably from the exhaust.
Perhaps the car is running lean?
PostPosted: Mon Mar 09, 2009 6:29 pm
You don't have fuel in the dashpot.
PostPosted: Mon Mar 09, 2009 6:30 pm
Your carburetor would need to be hundreds of degrees C to boil oil. It would flay the skin off your fingers when you removed the damper to check the level. What's in the dashpot?
PostPosted: Mon Mar 09, 2009 6:31 pm
Whats in the water? :mrgreen:
PostPosted: Mon Mar 09, 2009 7:12 pm
oh ok ummm.....
Well it looked like boiling.. it was very hot and there were a couple of bubble looking things. (hence why i said boiling)
Now i think about it it was able to stick finger into so oops :oops: :oops:
I think we fixed the problem anyway because we swapped [edit not dashpot] fuelbowl covers over and found out my other brother didnt hook up one of the leads :oops:
Thanks anyway
PostPosted: Mon Mar 09, 2009 7:18 pm
Stoopid minis. :lol:
PostPosted: Mon Mar 09, 2009 7:22 pm
ahh man im not having a good day.
i mean Fuel Bowl NOT dashpot...
its one of those days
well yeah what causes the petrol in the fuel bowl to be hot (dad said still not right)
sorry for another confusing post :lol:
PostPosted: Mon Mar 09, 2009 7:26 pm
That makes more sense. Stoopid minis :lol:
Radiant heat from the exhaust can heat up the fuel bowl and hence heat up the fuel. Usually on a hot day after sitting for a spell with a hot motor. The bowl is normally cooled by air flowing over it as you move, but if you are stopped it will heat up.
A heat shield fitted between the manifold and the carb is enough to stop this by reflecting heat away. Your twin SUs will have one although and they are available (or easily made) for a single SU, though it's not often a problem.
PostPosted: Mon Mar 09, 2009 7:30 pm
oh ok....
dad says is it possible for it to get that hot that it will evaporate inside the jet pipe at the bottom of the fuel bowl??
PostPosted: Mon Mar 09, 2009 7:54 pm
It can cause problems, but usually only hesitation. Once you get moving it will clear itself. There's a ton of other things that can cause this as well.
