It is currently Tue Aug 12, 2025 5:00 am
PostPosted: Wed Mar 11, 2009 8:47 pm
Is there a gasket under the top flange between the flange and the block?
David L
PostPosted: Wed Mar 11, 2009 8:51 pm
Memory stretch... there is a rubber O ring I think that sits on the spine of the dissy but I could be wrong
Lillee - 1969 Morris Mini K
PostPosted: Wed Mar 11, 2009 8:52 pm
There is an o-ring, but it is further down the shaft.
It negates the need for a gasket on your distributor.
PostPosted: Wed Mar 11, 2009 9:24 pm
There is the housing the goes into the block and the distributor shaft goes down the middle of - There is an O ring on the shaft that should stop oil coming up the shaft but what about between the housing and the block? The previous owner smothered this area in gasket goo obviously to stop oil leaking but there doesn't seem to be any gasket
David L
PostPosted: Wed Mar 11, 2009 9:35 pm
No gasket required. You do see that oil works it's way up the shaft, but it doesn't cause any leaks.
PostPosted: Wed Mar 11, 2009 9:43 pm
Is this what you are asking about David?
Definately fitted with an "O" ring!
Dave
PostPosted: Wed Mar 11, 2009 9:49 pm
Dave
Wow that looks pristine, how do you get things looking that clean and unworn?
Or is it a new part :?
The 850 Man
PostPosted: Wed Mar 11, 2009 10:00 pm
No not a new part, just the attention to detail I put into building my engines.
Dave
PostPosted: Wed Mar 11, 2009 10:13 pm
Thats what I mean - mine doesn't have any grooves in the body part but there is a grove at the top - Thanks now I'll look for an O ring to fit :wink:
David L
PostPosted: Wed Mar 11, 2009 10:18 pm
If yours dosen't have that groove maybe it is an early one.
If you want one with a groove contact me and i will give you one.
Dave
PostPosted: Wed Mar 11, 2009 10:23 pm
It is an early one - does the O ring sit in the middle rather than the top?
David L
PostPosted: Wed Mar 11, 2009 10:32 pm
The "O" ring goes in the "O" ring groove in the center of the machined section!
Not at the top......
Dave
PostPosted: Wed Mar 11, 2009 10:58 pm
Just double checked - definately no groove - pulled another out of another bare block I have here and guess what? - groove with O ring 8) It's now in the cleaning bath and I'll use that for the rebuild.
David L
PostPosted: Thu Mar 12, 2009 8:21 am
Yay I was almost right
Users browsing this forum: Bing [Bot] and 292 guests
