It is currently Sat Jul 19, 2025 9:22 am
 Post subject: chamber volume?
PostPosted: Sat Mar 14, 2009 5:21 pm
ok ive done some deshrouding and now i need to work out the volume of each chamber so they can all be balanced. whats the best way? i've heard of perspex being put over the chamber and filling the chamber with metho, then sucking the metho out with a syringe and measuring it that way. any other ideas?
cheers leighton
PostPosted: Sat Mar 14, 2009 5:28 pm
Tomboss Breweros
I used the perspex with a hole trick, sealed with grease to the face. I sprayed crc in the chamber then filled it with water using a syringe, measuring it on the way in, then just tip the water out.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Mar 14, 2009 7:10 pm
What he said ^^^. I add a bit of metho to the water to reduce surface tension.
PostPosted: Sat Mar 14, 2009 7:16 pm
ok sounds good thanks
PostPosted: Sat Mar 14, 2009 7:18 pm
I'm Bert , where's Ernie
sorry for the hijack,
but what the hell are you guys talking about?
the volume of the piston chamber?
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Sat Mar 14, 2009 7:20 pm
head chamber :wink:
PostPosted: Sat Mar 14, 2009 7:26 pm
Forum Graffiti
Tombo wrote:
I used the perspex with a hole trick..
a CD works well :wink:
PostPosted: Sat Mar 14, 2009 7:28 pm
There is a better more accurate way to get TOTAL chamber volume, if the head is on. Commonly was applied to motorbikes way back when...
Face car uphill a bit. Remove spark plugs.
Turn motor to TDC on #1 cylinder or whichever (check rotor points to that cylinder).
Using a burette or syringe (I use horsey ones) filled with ATF, fill the chamber to 1/2 way up the plug hole. Note the reading, it is total chamber volume.
To empty the chamber, put some rags on the front slam panel and front of motor, then crank motor for a few seconds with plugs out. There is only around 35cc or so in there..:mrgreen:
PostPosted: Sat Mar 14, 2009 7:35 pm
ooh sounds good.
whats ATF?
PostPosted: Sat Mar 14, 2009 7:42 pm
Automatic Tranny Fluid
PostPosted: Sat Mar 14, 2009 7:43 pm
automatic transmission fluid!
hot damn i know something!
edit: dammit gaf! :evil: :lol:
ATF= automatic transmission fluid as far as i know
edit: and appears that i was a bit slow reading
ATF = automatic transmission fluid.
Steve
PostPosted: Sat Mar 14, 2009 8:44 pm
You could use water, but I would want to start and run the motor pronto afterwards. :lol:
PostPosted: Sat Mar 14, 2009 8:48 pm
Tomboss Breweros
I love putting a little oil (3-4 pumps of an oil can) in a cars cylinders then starting it :lol: :lol: :lol:
Especially when a customer is present hahahaha :shock: :shock: :shock:
kimini wrote:
Jimmyinamini wrote:
Users browsing this forum: jason050377 and 76 guests
