It is currently Mon Jun 30, 2025 4:14 pm
PostPosted: Sun Mar 15, 2009 1:23 pm
Hopefully a quick question here.
I've just put new wheel bearings in in my front wheel hubs (with disk brakes). They are the tapered roller sort. Should the oil seals be tapped up hard against the inner race of the bearings? I have a bad feeling they shouldn't be.
I've already done one wheel and I tapped the front oil seal against the bearing, so the top of the seal was not flush with the end of the hub (as it probably should be)
Anyone know the answer here?
Tom
PostPosted: Sun Mar 15, 2009 1:42 pm
The seal should sit level with the outer edge of the hub on the outside one, and should have a spacer behind the seal on the inner one.
Cheers Pete
PostPosted: Sun Mar 15, 2009 2:35 pm
There was no spacer between the inner oil seal and bearing when I took it off, and I don't see why one would be needed. I can't see any spacers listed on the minisport site, which is where I bought the bearings.
I'm only aware of a spacer between the two bearings.
PostPosted: Sun Mar 15, 2009 2:41 pm
This space for rent
The Mini King cattledog on p.176 shows "21A1307 - Wheel Bearing seal spacer, front, Cooper S" between the inner bearing and oil seal.. although having said that my car doesn't have this spacer either.
PostPosted: Sun Mar 15, 2009 2:56 pm
Interesting.
I've looked at the Haynes manual now. It seems there is supposed to be a space there. Damn.
PostPosted: Sun Mar 15, 2009 2:59 pm
From memory some of the bearings have a spacer incorporated in them (??? Someone else can confirm , it's a while since I've done any) .
PostPosted: Sun Mar 15, 2009 3:03 pm
This space for rent
The tapered rollers have a spacer built into the ring of the inner race which keeps the inner and outer bearings separated, and ensures the correct preload on the bearings when torqued up. Ball bearings require a separate spacer ring to do the same job, but that's not what we're talking about here.
FWIW, I don't have this oil seal spacer on my car and it doesn't seem to have hurt any in the 18 months I've been running the discs..
PostPosted: Sun Mar 15, 2009 3:05 pm
No worries , was thinking about the previous bearings thread still and getting confused on which spacer .
PostPosted: Sun Mar 15, 2009 3:21 pm
Thanks sgc, that eases my mind a bit. :)
PostPosted: Sun Mar 15, 2009 7:51 pm
Timkin branded tapered roller bearings have the built in spacer as said above. Rear ones too
Lillee - 1969 Morris Mini K
PostPosted: Sun Mar 15, 2009 7:58 pm
The spacer he speaks of is not the one that is fitted between the bearings, it is a steel ring fitted between the inner bearing and the oil seal. It is supposed to be there, but if missing it won't cause any problems to leave it out.
Make sure the seal is parallel to the bearing face, and that the seal is spaced far enough out from the bearing that it runs on the cv's oil seal journal.
This space for rent
Do you mean they have a spacer (in place of 21A1307) to fix the position of the inner oil seal, or are you referring to the spacer built in to the inner race which fixes the two bearings' relative positions and sets preload when torqued up?
[edit] Never mind, Thanks Mick ;)
PostPosted: Sun Mar 15, 2009 8:00 pm
Try the pictures on the following link.
They show the spacer I was talking about, items 61 and 73.
However as stated buy others they are not really needed.
Cheers Pete
CLICKY HERE
PostPosted: Sun Mar 15, 2009 8:01 pm
There is a thin metal spacer ring fitted between the inner wheel bearing and the inner seal on tapered roller bearing cars.
This spaces the oil seal out from the bearing so it runs in the middle of the machined surface on the cv joint.
These spacers have been unavailable for years. Fit the seal so it is about 1/4" away from the inner bearing. :D
PostPosted: Sun Mar 15, 2009 8:04 pm
This space for rent
Explains why I don't have one then! Thanks Karcraft 8)
Users browsing this forum: No registered users and 72 guests
