4myego wrote:
Agree with DocMini
I recently talked to John at MiniKing about the best way to attach.
He said that NO POP RIVETS are required if you use the proper clips (John says these just pull out if the strip shrinks, which it does). The proper clips act to both hold the plastic flare in place and also the chrome cover strip. Well that's the original method
I have taped my strips to a length of copper pipe and hung out to straighten. when I am ready, I will attach as per Johns comments. Let you know.
Any other positive experiences??
Funny, John had this to say to me when I ordered mine a few days ago from MiniKing:
Hi Craig, John Smidt Is My name.
The clip You want is MYH45 There is a total of 24 clips used on the car Cost is A$0.24 each Post would be A$6.50.
I feel I must explain These are not ment to be used without using pop rivets aswell, However I use them without pop rivets Untill such time as the chrome strip starts to come away from the body, Then I use a pop rivet at each corner and one in the middle, By this time the chrome strip has expanded an contracted, So and when you fit the pop rivets The plastic is less likley to break away from the rivets, It has been My experience that it can be a fairly long time before you need to use pop rivets, I do hope I have explained this properly. ':shock:'
I guess I'll also attach it per John's comments. Have to check back in 6 months and see which version worked best!
