It is currently Sat Jul 19, 2025 1:13 pm
 Post subject: cant select gears!!!
PostPosted: Sat Mar 28, 2009 8:56 pm
I is a mookenik
ok today we swaped the motors over in the van and swaped the gear selectors aswell so instead of being remote, it is now a wand to suit the van..
problem is now i cant select gears.. i can get 1 and 4 and reverse but no 2nd or 3rd.. and this is without the motor running.
any ideas why??
 Post subject: Re: cant select gears!!!
PostPosted: Sat Mar 28, 2009 9:04 pm
any ideas why??
Yes
PostPosted: Sat Mar 28, 2009 9:08 pm
This space for rent
BALLISTIC wrote:
Yes
:lol:
Don't keep the poor boy in suspense.. care to share? :D
PostPosted: Sat Mar 28, 2009 9:23 pm
If a Remote I could lead you in the correct direection :roll:
PostPosted: Sat Mar 28, 2009 9:52 pm
I is a mookenik
so im guessing u cant help since its remote then gaf??
PostPosted: Sat Mar 28, 2009 9:58 pm
My guess(s) is that you either have the stick hitting the floor panel at the front of the gear shift hole,,, restricting full forward movement of the stick
which leads me to the 2nd part of the "guess(s)" which could possible be caused by the Knuckles on the top of the diff housing being incorrectly set
,,, just a guess(s) tho :-)
PostPosted: Sat Mar 28, 2009 9:59 pm
well you have gone from Remote change to a Wand which I have not installed.
If it was a Remote I would say you are a Tooth out or two from the gear solector to the spline in the remote
PostPosted: Sun Mar 29, 2009 7:58 am
I haven't got a clue so I'm no help to you at all :?
Dicko
PostPosted: Sun Mar 29, 2009 8:03 am
My bet is the splines on top.
The lever on the selector shaft (into the gearbox) should be horizontal in neutral position.
The RH one (on the shaft through the diff housing) is correct when the gearstick is pointing straight ahead in the 3-4 neutral position.
If gearstick is L or R of this, it's a spline tooth out.
Tighten the spline coupling bolts good and tight, if not they wear the shaft and the coupling too.
Users browsing this forum: Bing [Bot] and 72 guests
