It is currently Thu Jul 24, 2025 11:45 am
 Post subject: Hydro to Rubber
PostPosted: Sun Mar 29, 2009 6:43 pm
If I change to rubber cone from hydro suspension do I have to do anything to the sub frames where the hydro bags locate in the frames to then hold the rubber cones in place
PostPosted: Sun Mar 29, 2009 6:44 pm
you have to change the subframes also. to be truthfull I would stay with the Hydro's
PostPosted: Sun Mar 29, 2009 6:50 pm
Thanks gafmo , I thought that might be the case. I will have to keep looking for another hydro bag,, [as in the wanted section]
PostPosted: Sun Mar 29, 2009 6:55 pm
you're in Narellan, go see Mini King...
PostPosted: Sun Mar 29, 2009 7:05 pm
This can be done without changing the subframes by tapping back the tabs that retain the hydro bags. Done a few.
Steve
PostPosted: Sun Mar 29, 2009 7:44 pm
Give Ash some flowers Nick .
I love hydro mini's - don't change it unless you have exhausted all the other avenue's for finding 2nd hand bags.
PostPosted: Sun Mar 29, 2009 9:00 pm
I doubt you can go back to fitting hydro displacers once you butcher a subby for rubber cones.
If you can't find a silver S bag, I'd put a pair of Mini Deluxe or Mini-K ones in it.
With shocks on both types I can't tell the difference.
Having owned an S replica converted to rubber cones and Hi-Los, I wish the PO had left it alone. It handled no better (with Konis) than my hydro car does with Pedders on the front, and the ride was far worse.
PostPosted: Sun Mar 29, 2009 9:06 pm
thanks Doc . I have time up my sleeve at the moment so I will keep looking , long way to go with my resto , cheers Mark
Users browsing this forum: Bing [Bot], winabbey and 97 guests
