It is currently Sat Jul 26, 2025 10:31 am
 Post subject: Diff ratio pop quiz
PostPosted: Tue Mar 31, 2009 8:11 am
Hi,
I've got a moke 140kph speedo (860 turns per kilometre) in my 1293.
I checked it against my satnav and it appears to be 100% accurate.
Can anybody hazard a guess at to what diff I've got in the car.
PostPosted: Tue Mar 31, 2009 9:05 am
Tomboss Breweros
Open wheeler?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Mar 31, 2009 9:28 am
what size wheels?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Mar 31, 2009 9:47 am
What RPM does it sit on at 100km/h?
PostPosted: Tue Mar 31, 2009 9:49 am
Sorry. :oops:
10 inchers with 165/70 Falkens on them.
I don't have an operational Tacho at the moment.
PostPosted: Tue Mar 31, 2009 9:51 am
depends what speedo drive you have in the gearbox... obviously it's the correct one for the diff
PostPosted: Tue Mar 31, 2009 9:57 am
Fair enough, Didn't think of that. The gearbox and speedo have come out of two different cars, so I guess that I'm just lucky that they are an accurate combination.
I'll try and work it out when I get my tacho working.
Thanks.
PostPosted: Tue Mar 31, 2009 10:00 am
With those tyres I think you should be looking at 3750rpm @ 100km/h with a 3.44 diff.
PostPosted: Tue Mar 31, 2009 10:02 am
You have a 3.647:1 diff, an 860 turn/km Moke speedo is spot on with this ratio (and 165/70-10 Bridgestones) over the 5km road markers. :wink:
I had one in Barney.
There is also an 800 turns/km 140KMH Moke one, they are pretty close to correct with a 3.444 diff and 10" wheels.
PostPosted: Tue Mar 31, 2009 10:13 am
I seem to remember that the tacho used to read about 4000RPM at 100 KMH. Mind you the last time I had this engine in a car was 1995!
Thanks again guys.
PostPosted: Tue Mar 31, 2009 10:47 am
4k would be a 3.6.
PostPosted: Tue Mar 31, 2009 12:51 pm
So Doc is the Moke speedo in KMH? My 65 Deluxe has a 90 MPH speedo and I wanted to change to KMH so it should work if I can find a 860 turn/km Moke speedo?
(I think I have 3.6 ratio - whatever was in the 65 deluxe - 3 synchro box and 10" tyres)
Thanks
Dave K.
PostPosted: Tue Mar 31, 2009 12:53 pm
Is it blue?
PostPosted: Tue Mar 31, 2009 1:29 pm
Thanks
Yes later Mokes were KMH.
Bad news for you- the 998 Deluxe was 3.765:1 (same as 850). It's the Mini-K (and 1098 Clubby) that got the 3.647 diff.
It won't read correct, but not too far out.
PostPosted: Tue Mar 31, 2009 1:59 pm
Mien
Christ, you reckon they could have made it any more complicated??
Linus' speedo always read a tad high, but I knew that so I was ok. Then the speedo died. Don't know why, haven't had the time to check, and I'm not sure I'd know what to look for anyway. Now I just go by revs, and the rest of the traffic around me :D
