It is currently Sun Jul 27, 2025 8:39 pm
 Post subject: Zircon White
PostPosted: Tue Mar 24, 2009 8:35 pm
Anyone know where I can get Zircon White in clear over base for my MkII?
Or does anyone have a formula?
Cheers!
Now with 2 extra ports!
PostPosted: Tue Mar 24, 2009 9:38 pm
wander into a paint shop who do PPG paints and give them "Zircon White 12969"
from here -> http://www.ozcooper.com.au/paint_codes.htm
PostPosted: Tue Mar 24, 2009 10:05 pm
As far as I know PPG dont recomend putting a clear coat over their paint .
Is there another option?
Thanks.
PostPosted: Tue Mar 24, 2009 10:23 pm
Why the heck not? gotta be one of the strangest things ive heard in a while..... :?
If anything, brands tend to protest mixing with other brands... but its really not a big deal....
Other than that, how could you not clear over a basecoat?
The amount of times ive used ppg, and cleared it with other brands or ppg, I have never had a problem :)
Size DOES Matter!!!
PostPosted: Tue Mar 24, 2009 10:57 pm
"Other than that, how could you not clear over a basecoat? "
My inderstanding is that PPG 2pack paint is a direct gloss system, therefore not needing clear.
However to match the rest of the car I want the colour in 2pak+Clear
Maybe my smash repairer doesn't know what he is doing? No - I think he is well qualified in doing things properly.
To get the Sugarcane base coat we had PPG mix a small tin as they still have the formulae , then sprayed it out and had it Spectro match to have a Clear over base formulae which is know a known quantity. The purpose of this was to hopefully end up with something that is going to last well.
Maybe someone here has already done this with Zircon White?
Thanks.
PostPosted: Tue Mar 24, 2009 11:59 pm
nope your repairer is on the money, solid non metallic colours, in 2pakl dont require a clear coat. it can be put oin for the extra shine, but not neccesary!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Mar 25, 2009 9:13 am
well that is the first time you have mentioned that it is 2pack.... that and basecoat are completely different things. I was talking about basecoat, as that is what you had mentioned. Correct. You do not need to clear over 2pack because it is a gloss paint, but you can, as stated above, but yes its not necessary. Be more clear about what paint you are actually talking about if you want the right answers.
Size DOES Matter!!!
PostPosted: Sat Mar 28, 2009 10:30 pm
Appreciate your help, but you too can ask questions.
If I didnt provide enough info to respond correctly , ask me and Ill provide more.
Cheers.
 Post subject: Re: Zircon White
PostPosted: Sun Mar 29, 2009 3:18 pm
Thanks.
Zircon white isn't a common colour, so I doubt if anyone has done that. Wouldn't it be nice if there was a formula converter. I met a guy at Phillip Island who has a Zircon White MK2 - it looked like it had been repainted, but I don't have his contact details to ask him what sort of paint it was.
When I paint my cars, I'll be using Acrylic with no clear over it - I reckon clear coating is a sham, but that's just my personal opinion, which is irrelevant :)
PostPosted: Sun Mar 29, 2009 4:48 pm
Yeah it would be great to have an Ausmini formulae database for Acrylic & 2 pak.
Ill see if I can get the Sugar 2pak formula we had created incase any one might be able to use it.
I realise there are many variables in this , but its a start.
Cheers.
PostPosted: Tue Mar 31, 2009 10:59 am
From my Dulux paint book:
Zircon White 526-12969
Tinter / Setting
19206 / 442
00740 / 463
00742 / 478
05440 / 500
I've only seen Zircon white on one car. Looked pretty neat, but it is a very pale green to the eye. I even asked the owner what shade of green the car was!? :oops:
But, don't call it Zircon Green, or you might end up with Ford Zircon Green, which is a dark metallic green from about 1968 (XT Falcon GT colour)
For those who collect our Mini calendars, see March in 2007. Colour repro was actually quite good.
Watto.
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62, Steam and 90 guests
