It is currently Wed Jul 23, 2025 8:05 pm
 Post subject: Fuel hose length
PostPosted: Wed Apr 01, 2009 8:50 am
Can anyone tell me the length of the hose that goes from the end of the pipe at the firewall near the blanking plate/heater hose entry. to the Y piece connection pipe for twin carbies? The engine is not in the car yet so I can't measure my own and I want to get the metal braided fuel hoses and they come in fixed lengths.
David L
PostPosted: Wed Apr 01, 2009 9:02 am
If you fit a fuel filter here, then two of the small 3" engths are all you need, other than that a 6" length will make the gap.
If you get a longer piece and wish to cut it down, it's not so hard. Wrap the hose in electrical tape just once where you want to cut it, cut the hose and slide the rubber boot over the electrical tape, then pull the tape out from under the rubber boot.
PostPosted: Wed Apr 01, 2009 9:23 am
Thanks Mick - forgot about the fuel filter - so 2 x 3" will be the go :wink:
David L
PostPosted: Wed Apr 01, 2009 9:33 am
It will have to be a right angle fuel filter by the way. It makes for a neat fit.
PostPosted: Wed Apr 01, 2009 12:10 pm
I hope the hose inside these Bling things is rated for unleaded...
I trust the USA made hose with an SAE number instead. No Bling but they stay soft. 8)
PostPosted: Wed Apr 01, 2009 1:29 pm
I haven't pulled the braid off one of the hoses to find out, but it has been over 20 years now since unleaded joined the market....
I've never had a problem with the ones from Minispares anyway (touch wood)
PostPosted: Wed Apr 01, 2009 8:14 pm
G'day Wombat,
I' ve got a brand new braided one from Mini Kingdom that i brought years ago and it measures 355mm or 14 '' end to end, hope that helps.
Colin.
PostPosted: Wed Apr 01, 2009 8:38 pm
PM sent
David L
Users browsing this forum: Bing [Bot] and 94 guests
