It is currently Sat Jul 26, 2025 1:04 am
 Post subject: Bonnet Rattle
PostPosted: Wed Apr 01, 2009 8:14 pm
at certain revs im getting a consistant rattle between the bonnet and the body just under front window here....
any ideas of how to reduce or stop this? i was thinking of putting (jamming) a sliver of rubber in there, but this may not be easy if the bonnet is opened and closed
PostPosted: Wed Apr 01, 2009 8:21 pm
you could throw some sticky backed foam in the channels
PostPosted: Wed Apr 01, 2009 8:22 pm
ah good thinking! is that in anyway water proof? or will it need replacing every so often?
PostPosted: Wed Apr 01, 2009 8:23 pm
There should be a rubber strip in there. It sits on the lip of the gutter.
If you stick a bit of sponge in the channel it will attract moisture and start to rust.
PostPosted: Wed Apr 01, 2009 8:26 pm
A mate of mine with a roundie put 2 short pieces ( 2'' ) of pinchweld ,i think they call it ,( it;s the same stuff that goes around the doors less the rubber) ,on the lip at the top or backside of the bonnet, could be worth a try.
PostPosted: Wed Apr 01, 2009 8:27 pm
also a very good point
i think ill try my local hardware shop for some sticky rubber
there is nothing in the gutter or on the lip so im assuming thats why im getting that rattle
PostPosted: Wed Apr 01, 2009 8:28 pm
The proper bit was called "Channel- Bonnet drain" Part number HYB3743.
It was like a bit of pinchweld with a lip pointing up.
PostPosted: Wed Apr 01, 2009 8:52 pm
I think that this is what it looks like from the side...
PostPosted: Wed Apr 01, 2009 8:55 pm
The roundies had a bit of sponge (8x13?) in the channel. Even my 3/70 car has it. That moulded one in the pic is a Clubby thing... :lol:
PostPosted: Wed Apr 01, 2009 11:16 pm
Try a lump of wood and a big ratchet strap over it :D :D
seriously a strip of "U" shaped rubber woks well. I have heaps of rubber similar to the style that Morris 1100 showed but does not have the little lip. Pm and I will give you some
www.minisprintgt.com
PostPosted: Thu Apr 02, 2009 9:15 am
my bonnet pops open pretty much every time i take the car out and rattles when i'm idling at certain revs.
anyone know how to go about fixing that?
PostPosted: Thu Apr 02, 2009 9:26 am
bonnet strap :D
maybe try tinkering with the ( don't know what its called bit in the middle front of the bonnet that goes into hole)
has to have sonething to do with that
PostPosted: Thu Apr 02, 2009 11:37 am
couldnt have put it better than myself
Araldite a brick to the bonnet then put a fibre glass scoop over the top of it :roll:
David L
PostPosted: Thu Apr 02, 2009 11:44 am
LOL thats funny as, more downforce too.... me likes to corner fast. :twisted:
