It is currently Sat Jul 26, 2025 6:30 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 02, 2009 11:59 am
Fiji wrote:
maybe try tinkering with the ( don't know what its called bit in the middle front of the bonnet that goes into hole)
Latch Mechanism.
It sounds like it is not adjusted properly.
But do it urgently, Having a bonnet pop up at speed is not something you want to experience.
PostPosted: Thu Apr 02, 2009 4:09 pm
Check the spring on the main catch to make sure the latch returns properly, lubricate all moving parts and make sure the second catch is working properly as well.
Adding bonnet pins or a pair of straps on a road car in place of a standard catch is a disaster waiting to happen. Either someone will knick your pins or they will undo the straps, so when you get to 50kph up goes the bonnet.
PostPosted: Thu Apr 02, 2009 8:23 pm
I is a mookenik
lol... its the main catch on the front.... she use to rattle all the time on me just never got around to fixing it. leave the choke on and wait in front of the car and it will rattle push down on the front where the latch is and it will stop...
PostPosted: Thu Apr 02, 2009 8:38 pm
yeh i think i tried that, it would just end up popping back up and more rattleit seems like the bonnet is a bit twisted to (looking at the front of the mini) the right hand side pops up and doesnt sit flush
PostPosted: Thu Apr 02, 2009 8:39 pm
I is a mookenik
might need to align it..
A little piece of rubber on the front of the hook stops the rattle against the bonnet latch panel.
PostPosted: Fri Apr 03, 2009 4:56 pm
i have essentialy fixed most of the rattle
i did have the funny shaped rubber but in the "gutter" but it was not doinga good enough job at holding it still
so i bought a meter of 6mm vac hose and cut it open and wedged it in there :D
seems to have stopped most of the rattle, now all that is wrong is that there is a rubber stopper missing from the front right but have reduced that the same way as above
cheers for all your help
