It is currently Wed Jul 23, 2025 12:44 pm
PostPosted: Fri Apr 03, 2009 10:28 am
At some stage an after market aerial has been mounted on the front mudguard with it's obligatory hole. I don't what to use one of those chrome plugs - I'd prefer to restore to original surface.
How would you go about it?
David L
PostPosted: Fri Apr 03, 2009 10:48 am
With straw?
The best thing to do is weld it. Filler will sink back or fall out.
Get some copper behind the hole, and weld it up (weld wont stick to the copper
so the inside stays smoothish).
If the hole is big enough put a fill in piece of steel in there.
PostPosted: Fri Apr 03, 2009 10:50 am
Spade should be enough to fill a hole...
Wait...
I'd imagine you source a piece of steel simular to a Mini body, cut it, shape it, weld in and grind flat.
PostPosted: Fri Apr 03, 2009 11:20 am
Thanks guys - just wanted to confirm my thoughts before I took a grinder to perfectly good paint work :roll:
David L
PostPosted: Fri Apr 03, 2009 11:21 am
Or find an old AM radio and put an antenna back in the hole , doesn't matter if it works or not really , so long as it looks like it should .
PostPosted: Fri Apr 03, 2009 11:30 am
Bandaids.
PostPosted: Fri Apr 03, 2009 11:50 am
I used to cut a rectangle of steel bigger than the hole and tack weld it underneath then cut a circle of steel the right size and weld it in the hole, grind and bog to fit.
PostPosted: Fri Apr 03, 2009 12:15 pm
Resident Haemorrhoid
Just dont let BIAM do it or you will have plenty of Blood on the paint to clean off :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Fri Apr 03, 2009 1:21 pm
Good question wombat, I have the same problem. As a short term fix I found the rubber grommets from Clark rubber are very low profile and are hardly noticeable with a smooth surface almost shinny. Not sure if you have clark rubber there but I could send you one if you want. Cheers.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Apr 03, 2009 2:02 pm
A bloke I know has the middle finger from a pink rubber glove fill with foam and a dirty finger nail drawn on it. It just sticks up out the hole :)
but then he drives a commode door
www.minisprintgt.com
PostPosted: Fri Apr 03, 2009 3:00 pm
poeee wrote:
Bandaids.
hey! no grinder has touched my car since i got it :P
78 Leyland Mini - Prince
PostPosted: Sun Apr 05, 2009 12:05 pm
BTW,
Where can you get those chrome blanking parts for the aerial hole?
Thanks........
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Apr 05, 2009 1:18 pm
Just put a bloody aerial in it.. :twisted:
I like the Jaycar rubber ones, they don't break. If they perish with age I just screw a new one on.
PostPosted: Sun Apr 05, 2009 10:02 pm
You can see the square holes in this pic that a PO had put in for a wing mirror.
and in this one the large rectangular hole they had made for the aerial on the other side
Here is the mirror holes filled with small pieces cut from an old battery box, welded in and ground back.
same treatment for the aerial hole
This was my first ever attempt at welding a panel, so i was pretty happy.
michael
PostPosted: Sun Apr 05, 2009 10:55 pm
michael
I did mine too, it's not that difficult with a good mig welder, just work use a quick feed rate and a low power setting.
The 850 Man
Users browsing this forum: 1071 S and 87 guests
