It is currently Sat Jun 21, 2025 12:43 pm
 Post subject: Roll Cage
PostPosted: Thu Feb 24, 2005 9:18 am
What sort of price do those nice bolt in cages go for with the single bar over the rear of the seats?
Where is the best place to buy? Mini places, get one made etc etc?
Any info appreciated,
Big Dan[/i]
Be afraid, be very afraid...The Clubman is coming...!!
PostPosted: Thu Feb 24, 2005 9:36 am
Hey,
iv got one like that,its half alloy,bolts to the parcel shelf and behind the front seats,2 bars goto the parcel shelf,one goes around the inside of the car with a big cross bar from the passengers head to the drivers floor
looks tops but cops dont like with back seats :(
i think the going price for em is $200-$250 for a polished one,mine was CAMS approved in its day
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 10:13 am
Alloy cages are no longer CAMS legal but you can still buy them and they look neat.
Cross bars are n longer legal as far as I know.
Bond Roll bars at Regents park do a nice four point (half cage) in alloy without cross bar for about $350 I think. This has two bars that go to rear shelf.
Must get Engineers certificate cause if you have an accident with a Roll cage installed you will be toast.
Engineer will re class the car as 2 seat and some will make you remove rear seat.
PostPosted: Thu Feb 24, 2005 10:14 am
Just looking at my option Kazjim.
Any rough idea of $$$$$
PM me if you like.
Thanks
Chris
PostPosted: Thu Feb 24, 2005 10:21 am
yeah i was looking at steel ones but can't find anything on the web.
PostPosted: Thu Feb 24, 2005 11:03 am
THey are rare as wooden horse shite on ebay and a bitch to install second hand. You are best to go to Bond Roll bars.
PostPosted: Thu Feb 24, 2005 3:00 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i sold a full steel cage about 8 9 months ago
makka
PostPosted: Thu Feb 24, 2005 4:45 pm
how much for just so i have sum sort of a idea on price
PostPosted: Thu Feb 24, 2005 4:46 pm
Thier is a trick with installing steel role cages....
A nice strong piece of rope..A jimmy bar and start twisting..now with the Jimmy bar you have to have a hole at one end so you can tie it off.
The idea is to place the jimmy bar inbetween the rope's which is tied of around each of the bars and use the bar to twist both legs in and tie off...Warning if you let go of the bar..Very Dangerus...it will go flying
Prior to this take out all seats and steering wheel and fit
PostPosted: Thu Feb 24, 2005 5:20 pm
I have a Bond Roll bars alloy half cage sitting in the shed. It is very easy to fit in an early mini (low back seats) and would be a bit harder with late seats. You just fold the seats foward and poke the bar through the door and slip it into the rear pockets and then stand it up. Then you add the rear supports and it is done!
I know of a few cars that have been engineered as a two seat car because of the bar but they still have the rear seat.
If you want to make a bar you buy the right grade of pipe and get it bent by a very good exhaust bloke (not a midas or similar)
If you just want a bar for show use exhaust pipe!
If you want a bar for motorsport get a proper steel all welded bar. (It bolts to the floor but all the bars are welded to each other.)
PostPosted: Thu Feb 24, 2005 5:59 pm
Front section
Lying in waiting
PostPosted: Mon Feb 28, 2005 9:48 am
any idea on the cost of a steel half cage anyone? 8)
[Maverick] 1971 Mini K
Users browsing this forum: MiniPete and 80 guests
