It is currently Sun Jul 27, 2025 8:35 pm
PostPosted: Thu Apr 16, 2009 12:30 pm
Anyone know any good places in sydney to get a shell paint stripped?
Looking at some form of media blasting but from quotes i've received ringing around they are from $1-3000 depending where you go and what they use...
The shell has a bit of rust and want to get it back to bare metal so it can all be seen and removed.
PostPosted: Thu Apr 16, 2009 12:41 pm
what do you have the most of Josh, time or money? :D
PostPosted: Thu Apr 16, 2009 12:46 pm
Neither at the moment!! :lol:
I don't want to have to find the time to paint strip...
Someone tell me there is a easier cheaper way :D
PostPosted: Thu Apr 16, 2009 2:04 pm
Redistrip in Bessemer St blacktown
Soda Blast as per Anton's mini experience articles
Claude from Impact Glass Beading in Romford Rd Blacktown/kings park.
I've used options 1&3 - 1 for hanging panels and doors; 3 for the shell.
whilst claude is a friend, if I had my time over I would probably try options 1or2 if I had another shell to do. Not that there is anything wrong with grit blasting, I just think option 1 leaves a better finish.
KB
PostPosted: Thu Apr 16, 2009 2:13 pm
Look at this
http://www.ausmini.com/forums/viewtopic ... highlight=
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Thu Apr 16, 2009 4:07 pm
I've heard lots of negatives about SodaBlast - not about the job itself but with issues getting the paint to adhere to the shell after
PostPosted: Thu Apr 16, 2009 4:09 pm
cd wrote:
Thanks for the link, I see you used Austec, they seem great but the quote of $2800+250 for a sealer was too much $$$ :(
PostPosted: Thu Apr 16, 2009 5:20 pm
Why not try stripping it yourself? This looks pretty effective, and cheap!
http://www.ausmini.com/forums/viewtopic.php?t=13620
PostPosted: Thu Apr 16, 2009 10:20 pm
I paint stripped mine, took a lot of time.
Depends on the number of coats of paint, how much bog , original primer etc.
Can cost a fair amount for the paint stripper. I got mine from bunnings, I think about $66 (I think) a tin & used about 6 tins.
After the stripping put on etch primer soon after. It took many months to do the whole car. Thats outside, inside the mini (whole car).
I would consider blasting next time.
I still had to blast under the bonnet, boot lid & roof gutter, near the seams. This was to remove some surface rust that was not really accessable with other tools. Dont get rid of the surface rust it may come back to bite you.
Best to use plastic media blast in certain areas so the temperature doesnt effect the outer skin.
Inside the bonnet I had a couple of minor surface rust areas. had to use a harder blast for the rust. This affected the outer skin. After filing the skin I still had to use a bit of body filler.
Good luck with all
1927 Austin 7
PostPosted: Thu Apr 16, 2009 10:26 pm
Josh you lazy git, Paint strip it and knotted wire wheel. It took me about 8 hours to do the van and about 10 hours to do the cooper S.... One tin of paint stripper for each. It's messy but it is cheap and effective.
PostPosted: Fri Apr 17, 2009 2:54 pm
:lol:
We're going to do it ourselves and organise a working bee BBQ day ;)
PostPosted: Fri Apr 17, 2009 2:57 pm
Mini Mad wrote:
:lol:
I haven't heard much of your former slave Duc - what did you do to him?
PostPosted: Fri Apr 17, 2009 2:59 pm
We will pull him out from his hole in the ground and reenlist him :twisted:
Photos to come 8)
PostPosted: Fri Apr 17, 2009 3:11 pm
Hey Josh,
What car are you painting?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri Apr 17, 2009 3:42 pm
Austech at Chipping Norton did a great job on my van... The first time it was stripped :roll: Those plastic mesh stripping discs for grinders work extremely well, noisy and a little time consuming but sure will not cost you anywhere near 3K
Life's a garden.... Dig It!
Users browsing this forum: Goldbrocade_62 and 97 guests
