It is currently Fri Aug 01, 2025 10:55 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 22, 2009 7:26 am
lmbm wrote:
Hi Kevin,
if the dizzy driveshaft has too much endfloat how can we cure this ?
the A series block i've sourced has a bit of endfloat in the dizzy driveshaft.
Thanks
Luis
Measure the endfload while installed, use a dial gauge down the hole and screw a stud in to push/pull it in & out.
Then, remove the dizzy mounting flange casting, put in a lathe and machine (endfload-.005") from under the head. Refit and check endfloat.
Don't go below .004" clearance, you need room for shaft expansion and an oil film.
