It is currently Wed Jul 23, 2025 2:52 am
PostPosted: Wed Apr 22, 2009 12:20 pm
I pulled apart the hubs on my race car last night and it had spacers between the seals and the bearings. I have had a few Minis with discs and never seen this before. Maybe they were just left out? Is this standard? Should they be on the inners and outers?
Pete
PostPosted: Wed Apr 22, 2009 12:40 pm
i had this problem with mine not long ago
PostPosted: Wed Apr 22, 2009 12:43 pm
the big split spacer goes between the inboard bearing and the seal, a small solid spacer goes between the bearings.
PostPosted: Wed Apr 22, 2009 1:58 pm
Pete
they're just to stop the inner seal from going too far into the hub, and to make sure it goes in straight - if you've got them, put them back in, if they're missing, it's no big deal
so yes, yes, and no
PostPosted: Wed Apr 22, 2009 2:28 pm
21A1307 is p/no . Probably are NLA now like lots of little stuff.
For tapered rollers they are .229" (5.81mm) thick, if you want to get some made... :wink:
The drum brake ones (used with ball bearings) are only .094" thick.
PostPosted: Wed Apr 22, 2009 10:25 pm
Thanks guys. I'll put them back on the inners.
Pete
PostPosted: Thu Apr 23, 2009 4:58 pm
This space for rent
Yep, I don't have them and don't have any problems.
