Hi everyone,
I finally got around to buying two seals for where the selector shaft goes into the rod change gearbox on my mini. I knocked out the roll pin (eventually :p), but had some troubles after that.
Firstly, I wanted to remove the old seal. The problem was, it was stuck in pretty firmly the whole way around (like it had been glued there or something, I dunno...). In hindsight, I probably should have just left it there and stuck a new seal or two on top (I'm a noob though, so this hindsight may also be wrong!). Instead, in my stupidity, I hacked away at it with a small screwdriver and removed most of it.. in bits. So my first problem is that I'm afraid the remaining bits of old seal will mess up the new seal(s), causing them to leak too.
Second problem is that I don't know which way around the seal is meant to go in
Third problem is I'm not sure how far the seal should go in... At the moment it sticks out quite a long way, but this might be because:
a) I've got it in the wrong way around
b) Bits of old seal are stopping it going all the way in
So really problem 3 will hopefully be solved if i can solve problems 1 and 2..
Anyway, any help on any of these three problems would be very greatly appreciated!
Harry
