It is currently Sat Jul 19, 2025 11:40 am
 Post subject: 1st Gear Jumps Out
PostPosted: Thu Apr 23, 2009 5:49 pm
Hi Guys,
Can anyone help with this? Today I have had 1st gear jumping out, it will go into gear easy but once you take off it jumps out a making a banging noise, also it feels as if 3rd gear will not engage all the way. :(
Thanks for your help.
PostPosted: Thu Apr 23, 2009 6:14 pm
Check your engine steady bars and the bushes in them , also your engine mounts . Sounds like the engine could be moving more than it's meant to .
PostPosted: Thu Apr 23, 2009 7:01 pm
The Mini King
Is this a 3 Speed sync Or a 4 Spd Sync Gearbox
PostPosted: Thu Apr 23, 2009 8:45 pm
It's a 4 speed sync gearbox.
PostPosted: Thu Apr 23, 2009 9:37 pm
The Mini King
Then it is more likley to be one of the following. engine mounts, Gear lever worn, ( the slot on the side of the gearlever wears and sometimes does not allow proper selection of gears ) the connecting coupling and or roll pins worn, This is not to say that it does not have internal problems, But I would check above mentioned items first
PostPosted: Thu Apr 23, 2009 10:09 pm
On a similar note, my gearbox jumps out of reverse, only under power and not on the over run. Any suggestions welcome.
 Post subject: Gear lever
PostPosted: Thu Apr 23, 2009 10:20 pm
Also check the knuckles behind the engine they might be loose on the splines. Tighten the bolts that clamp them on. You will know that it is this fault as the gear lever will feel like a stick in a bucket. Therefor gear lever will reach the limit of travel before it engages the gear fully.
"Let us remove your "SHORTS"
 Post subject: Re: Gear lever
PostPosted: Thu Apr 23, 2009 10:36 pm
The Mini King
Good point I assumed it was a Rod Change ( dont ask why Because I do not Know )
PostPosted: Fri Apr 24, 2009 4:32 pm
I have checked the mounts and replaced the Bushes on the steady bar, It still has the problem, seems to be worse will not pick up 1st gear at all just the sound of the teeth running over the top of each other? :?
