It is currently Fri Jul 18, 2025 2:42 pm
 Post subject: strange engine noise
PostPosted: Fri Feb 25, 2005 6:23 pm
On my way home from work today the engine started to make a strang noise.
It has suddenly devolped a loud squeeking noise which appeard to be coming from the radiator side top or rear of the engine. When l got home l removed the alternator and ran the motor to see if that was the problem. It wasnt the noise is still there. The only other moving part apart from the motor itself is the fuel pump. Could this be the problem or do you think it may be internal? Apart from this squeeking noise he motor is running ok and is not overheating at this stage.
cheers chasg
PostPosted: Fri Feb 25, 2005 7:33 pm
water pump??
1974 Moke - 998cc
PostPosted: Fri Feb 25, 2005 7:52 pm
When l removed the alternator to check for the noise and started the motor the water pump wasnt working as the fan belt wasnt connected. However the noise was still there therefore l dont think it is the water pump
PostPosted: Sat Feb 26, 2005 9:07 pm
Found the problem today. Turn out to be a worn rocker shaft at no3 rocker. Replaced it with spare rocker arm and shaft assembly l had . Loud sqeeking noise now gone.
cheers chasg
PostPosted: Sun Feb 27, 2005 2:51 pm
thanks for the update
would you replace all the other ones as well?
Inconspicuously Conspicuous
PostPosted: Sun Feb 27, 2005 3:47 pm
Um... I think that's what he said, Duc- rocker arm & shaft assembly... :wink:
PostPosted: Sun Feb 27, 2005 4:07 pm
"shaft at no3 rocker"
hehe
sorry i thought he did something just to no3 rocker
thought he was talking about the shaft that goes down into the block (pushrod?)
he means the shaft running along the top that holds all the rockers?
PostPosted: Sun Feb 27, 2005 4:28 pm
Yeh. That one.8)
Users browsing this forum: No registered users and 112 guests
