It is currently Wed Jul 16, 2025 7:15 pm
PostPosted: Thu Apr 23, 2009 9:29 pm
My current Rod change, which I bought 2nd hand, doesn't leak at all either.
Dicko
PostPosted: Fri Apr 24, 2009 11:20 am
Thanks for the suggestions!
I'm having another look at it now, and I'm suspicious that what I thought was the 'bottom' of the hole (where the seals go) is actually another seal.. I think this because there's only about 4 or 5mm between the edge of the housing and the bottom of the hole, and I don't see how 3 seals could possibly fit into that space!
To confirm my suspicions, does anybody know how deep the hole should be when empty of seals?
Thanks,
Harry
PostPosted: Fri Apr 24, 2009 11:36 am
i have once or twice taken the selector out when doing a rebuid and stuck it in the lathe and put a spiral grove on it that ends up in a groove that goes all the way round the shaft to try and keep the oil in. It's worked so far
PostPosted: Fri Apr 24, 2009 1:03 pm
Thanks,
Harry
It's a lot more than 4 or 5mm, like I said I have seen 3 seals in there.
PostPosted: Fri Apr 24, 2009 1:10 pm
Great, thanks for that drmini!
I'll have another go at pulling them out :p
