It is currently Wed Jul 09, 2025 4:48 am
 Post subject: bypass hose.....
PostPosted: Fri Apr 24, 2009 3:17 pm
Currently got the water pump off my car so while evrything is apart going to replace the bypass hose(currently has the confoluted type) with a solid piece of hose...
What length should it be? thanks
PostPosted: Fri Apr 24, 2009 3:20 pm
Sit the pump on there, cut the hose about 1mm longer than the total visible room for it.
Use 1/2" heater hose, or 15/32 vacuum hose (stronger). :wink:
Users browsing this forum: No registered users and 29 guests
