It is currently Sat Aug 16, 2025 3:15 am
PostPosted: Sat Apr 25, 2009 4:32 pm
just went out and adjusted the brakes for the run tomorrow, i've got a beautiful firm pedal. rock solid. took it for a test drive, works fantastic.
I have about 2 inches of pedal travel, maybe less. is this too solid? it has less travel than the 97 festiva sitting in the driveway.
should i back it off just a little?
on the test drive a cruised downhill with the engine off to see if i could hear any scraping, but nothing. i also applied the brakes with the engine off, no squeak, no strange noise, just a nice, clean stop. which suggests to me that the pedal travel is ok
cheers all
(oh PS, drums all round)
78 Leyland Mini - Prince
PostPosted: Sat Apr 25, 2009 4:34 pm
How would you slacken them off?? Put some air back in??
You've done a perfect job of bleeding and adjusting the brakes.
PostPosted: Sat Apr 25, 2009 4:41 pm
hahaha good one!
i did not bleed, only adjust
maybe the travel is less than one inch...
PostPosted: Sat Apr 25, 2009 4:45 pm
You might smack your head on the windscreen tomorrow now because they're so good.
PostPosted: Sat Apr 25, 2009 4:48 pm
yeah probably... better wear a helmet
PostPosted: Sat Apr 25, 2009 4:49 pm
If only the brakes on cluby could have been that good :cry:
PostPosted: Sat Apr 25, 2009 4:51 pm
they will be crap again in a week, don't worry
PostPosted: Sat Apr 25, 2009 5:54 pm
Get discs.
Users browsing this forum: Bing [Bot] and 347 guests
