It is currently Sat Jul 26, 2025 10:26 am
 Post subject: Indicators not working
PostPosted: Thu Apr 30, 2009 11:04 am
hi all
today, the little girl decided that the indicators aren't really important and that they should stop working.
Basically, when i put the indicator on, it "blinks" once or twice and then dies.
Same goes for the hazard lights...
any idea why, and how to fix it and where to get parts from really really quickly (can't driver her until she is fixed?)
thanks
Deb
PostPosted: Thu Apr 30, 2009 11:07 am
try and check for a bat flattery
PostPosted: Thu Apr 30, 2009 11:09 am
she drove fine to work and started first go.... so battery must be ok??
PostPosted: Thu Apr 30, 2009 11:10 am
is the indicator problem with engine on or off or its makes no difference?
PostPosted: Thu Apr 30, 2009 11:11 am
did not try it with engine off. damn.
PostPosted: Thu Apr 30, 2009 12:53 pm
If it flashes normally, and all the bulbs are flashing as they should. I would suggest looking at the flasher can relay. It may have a worn out old contact. Swap it out with a known good one (it just unplugs) and replace it with a new one from supercrap or otherwise. They cost between 13 and 30 bucks for the flash flashers, but a standard flasher can is fine.
PostPosted: Thu Apr 30, 2009 12:55 pm
thanks Mick
mine is a Rover Mini so would supercrap have the flash thingo for it?
PostPosted: Thu Apr 30, 2009 12:59 pm
dribble1 wrote:
thanks Mick
They will. It will have one of three plug shapes, so pull the one you have out before you wander down to be sure you get the right one. it will be in the isle with the electrical bulbs etc, hanging on the rack in the same little packages the connectors etc come in.
PostPosted: Thu Apr 30, 2009 1:02 pm
fantastic... will go there after work tonight.
thanks Mick, hopefully it fixes it as i am not a big fan of sticking my arm out the window to let people know i am turning!!
PostPosted: Thu Apr 30, 2009 1:07 pm
Just keep turning the indicator arm on and off. Then you can customise the indicator cadence to the music you are listening to.
Country and Western, Polka, Rockabilly and Trance.
PostPosted: Thu Apr 30, 2009 1:46 pm
Rover Cooper
your a legend Mick
PostPosted: Fri May 01, 2009 6:36 pm
HELP please!!!
have figured out we need a new flasher can/unit thingo.
but where the heck is it? I have the CD rom for Minis but can't find it in there....
Mine is a 1997 Rover Mini. Some diagrams look like it is behind the dash??
Any help would be great.
thanks again
Deb
PostPosted: Fri May 01, 2009 6:48 pm
Have a look here
Original Rover Dealer Workshop and other manuals as supplied to the dealership on CD or is that the one you have?
http://mini.nicehelp.co.uk/
Page 1 Description and Operation - Electrical section Workshop Manual
Looks like top centre of firewall under bonnet
David L
PostPosted: Fri May 01, 2009 6:51 pm
When you pull the dashboard off, this is what's behind it:
PostPosted: Fri May 01, 2009 7:18 pm
You guys are worth your weight in cartons...
thanks so much... next question, how do you get the dash off without damaging it (is one of the woodgrain ones....)
thanks again.
Deb
Users browsing this forum: TartanRed and 73 guests
