It is currently Sat Jul 19, 2025 12:11 am
 Post subject: SC12 cleaning
PostPosted: Fri May 01, 2009 3:12 pm
to those who have bought one and thought that the internals needed a good scrubbing what did they use im thinking about churing some degreaser thru it for a while.
PostPosted: Fri May 01, 2009 9:52 pm
I'm not sure what to use but make sure it won't damage the seals in the bearings.
PostPosted: Fri May 01, 2009 11:17 pm
yeah Im a bit scared, it just has a far bit of carbon build up on the rotors.
PostPosted: Sat May 02, 2009 7:08 am
If you really need to clean it, I would pull the rotors out first... for reason above.
PostPosted: Sat May 02, 2009 9:56 am
How do you get carbon build up on a supercharger? There should only have been fresh air running through it :?
The 850 Man
PostPosted: Sat May 02, 2009 10:19 am
yeah thats what im thinking. everything rotates freely and cleanly
PostPosted: Sat May 02, 2009 10:31 am
The build up is from the PCV system.
All the engine vents feed back through the inlet on the emissions control systems on Jap (modern) cars.
Not really something I would bother about trying to clean
PostPosted: Sat May 02, 2009 11:52 am
yeah ok sweet.
PostPosted: Tue May 05, 2009 2:38 pm
what about petrol? it will be going through the rotors anyway???
Enjoy Chris ;)
PostPosted: Fri May 08, 2009 8:38 pm
I changed the head on my car last weekend and as such took the blower off.
Mine was very clean on the inside. You could eat off of it! (Although it may taste a bit petroley) Unlike the outside of it which was filthy! :lol:
Basically, if it moves freely I wouldn't bother cleaning it, it should clean as it runs with all that petrol flowing through.
PostPosted: Fri May 08, 2009 9:24 pm
ahh yes but it is worth just giving it a little rinse with petrol B4 fitting it As a just incase.
PostPosted: Fri May 08, 2009 10:05 pm
Carby Cleaner, plenty of it. Don't be scared
PostPosted: Tue Aug 04, 2009 5:22 am
I just wiped mine out until it turned with easy, just used loads of paper towel.
PostPosted: Tue Aug 04, 2009 2:57 pm
yep like willy said carby cleaner works a treat smells good to.
cheers dan
Cheers Dan
PostPosted: Tue Aug 04, 2009 6:58 pm
I was worried that the carb cleaner might attack the seals? nasty stuff I cleaned the carb out with it and burnt a big patch on the lawn. still hasn't grown back.. Wife doesn't like it.
