It is currently Tue Jul 22, 2025 5:24 am
PostPosted: Sun May 03, 2009 9:48 pm
I'm trying to doing some custom internal boot hinges on the mini (yes yes, its still NOT done!) Anyway, been off the project for a long time, and sick of not having my car done.
So, has anybody seen anything? I'm having trouble with getting them so the boot lid clears the bodywork.
PostPosted: Sun May 03, 2009 9:55 pm
Dont know why but bonnet hindge came to mind . Just the shape might be something to look at
cheers Mark
PostPosted: Sun May 03, 2009 9:58 pm
Maybe that's trying to tell you something...
But keep trying, it'll be great if you can sort it out, something different :D
Dicko
PostPosted: Sun May 03, 2009 9:59 pm
One of our members went through this about 10 years ago. After lots of trials and grief he came to the conclusion it was never going to work ,as he could not get the pivots in the right place.
So he gave up, put 2 guide lugs on it and made it a lift-out boot. :wink:
PostPosted: Sun May 03, 2009 10:01 pm
I have a feeling its a combination of the curve of the boot, as well as the fact that the pivot point needs to be on the wrong side of the steel :?
PostPosted: Sun May 03, 2009 10:11 pm
found these somewhere on the net some time ago..
tim
PostPosted: Sun May 03, 2009 10:17 pm
Thank you very much. I'm not worried if the boot won't open 100% like normal, as by the time the car is finished, there won't be any room anyway, spare tire, air-con system, amps etc.
PostPosted: Sun May 03, 2009 10:18 pm
the beauty of this is, instead of bolting the hinge to the boot, you could use removable pins, making the boot easily removable. I have similar pins holding my bonnet hinges onto the bonnet.
similar to these:
http://www.makefast.com/marine_section/ ... p_pins.asp
tim
PostPosted: Mon May 04, 2009 9:52 pm
i need the same thing :( not going to be fun.... though those ones on the blue mini look like they will work... or just make up something similar,
are u going to run a lock on the outside?
PostPosted: Mon May 04, 2009 10:26 pm
Kev,
10 years! your making me feel old.
All worked very well until the day my son twisted the handle and I lost the bootlid when I hit a bump.
PostPosted: Mon May 04, 2009 10:27 pm
BTw, it was just two pegs on the inside on the bootlid that slipped into the bootand you did the boot up as normal.
PostPosted: Wed May 06, 2009 8:33 pm
Oz, that's what mine will be like (body wise), I've de-bumpered it, but I've added (1/2 so far) a number plate recess. It'll get a late model electric boot release (with a cable to the drivers foot well.
I've got my mounting position worked out and a quick test with 1 hinge 1/2 mocked up it was going to work, so I'm proceeding to make some better final pieces.
Do you guys think a right angle of 1.6mm gal RHS will be OK for the base mount welded to the floor of the boot (1/4" UNF pivot)? I know they'll handle the weight of the boot lid, but should I go stronger safety wise?
PostPosted: Wed May 06, 2009 9:59 pm
i was thinking about this the other day.. id like to make something that came out a bit then went up and sat where the rear window is would be very hard to do and would need alot of movement in the hinges but would look cool
Potato
PostPosted: Thu May 07, 2009 7:49 am
hey guys there is an thread about this on the mini forum uk.
they used a strut with it also to get this all working.
you would have to do a hunt but it is there.
PostPosted: Thu May 07, 2009 7:55 am
I did try a search there, but I'll have a better look. But, I've had success with 1 mockup hinge, so I'm progressing on.
What do you guys think would look better, polished ally hinge arms or nice painted steel?
Users browsing this forum: Bing [Bot] and 94 guests
