DarkenMini wrote:
ahh thanks very much so i will need to get a dialer and circle protractor plus a 4deg Woodruff key. what does the woodruff key actualy do?
The woodruff key is a semi-circular key that connects the sprocket to the camshaft.
Don't buy an offset one, yet.
You need to assemble it with a STD woodruff key first, and check the timing.
Then see how far it is out, if at all.
It might be OK...
You can buy offset keys from 1-9° in 1° steps, from Minispares UK.
Note- the key just locates the sprocket and cam, the drive is (or should be) transmitted by the fact that the nut is torqued up to 72lb/ft.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
