It is currently Thu Aug 07, 2025 9:37 am
PostPosted: Wed May 06, 2009 12:27 pm
I've seen 5/16" and 3/8" cutters advertised and wonder what size you need for Minis and Mokes ?
David L
PostPosted: Wed May 06, 2009 12:38 pm
I think from memory 5/16" is the size... :wink:
PostPosted: Wed May 06, 2009 1:53 pm
David,
I would say it depends on how good you are at finding the centre of the spot!
5/16" would be good if you are sure of hitting the centre every time!!
Dave
PostPosted: Wed May 06, 2009 2:24 pm
sitnlo62 wrote:
David,
Dave
The ones I'm looking at have a retractable centre point - line it up then push down to engage the cutters
David L
PostPosted: Wed May 06, 2009 2:30 pm
I haven't heard anything good about those, but some pretty bad press, mainly in the life of the cutters. Spot weld drills, i.e. a drill with a little drill centre and then flat cutting area out to the diametre, are much better. Frost in the UK have them but you may be able to find them locally.
I wouldn't worry about finding the centre exactly each time, as you'll be able to break the little weld that remains; it won't be very strong.
PostPosted: Wed May 06, 2009 2:36 pm
I would have said inconsistent at best..
PostPosted: Wed May 06, 2009 3:15 pm
The retractable centers are crap. They jam up...
Wombat wrote:
sitnlo62 wrote:
David,
Dave
Thats fair enough David but you have to put that center point somewhere.
The point is that you have to decide where centre is, not always easy.
Dave
PostPosted: Sun May 10, 2009 2:37 am
I had to get a 8mm puntlaasboor because they don't believe in the empire here :roll:
It did the drip rails just fine. :)
