DarkenMini wrote:
What engine work have you done to your 998/1100 engine Like cam, Crank, rockers, flywheel, what compression, Carby.
The plan for me is 1100 crank with all the good stuff done to it, re13 cam, hif38, 12g295 head, Lightened flywheel, rebuilt gear box.
with a 998 engine and the hif38 SC12 and 295 setup any Su needle sugestions I know this is a stab in the dark but worth a try.
How much boost are you planning on running? That will determine the compression ratio, but I'd stay around the 8.5-9-5 mark depending. Ideally you'll want to run a HIF44 rather than the 1.5" to get the most out of your setup. Graham Russell makes an FI version of the cam called an RE13T, a few on here have used it with great success. Try to find a virgin 1100 crank which hasn't had a regrind yet as you'll want all the meat you can get in the journals.
Ah, that's about all I can think of atm...
