This f@#$ing van has got me stuffed, I can't figure out what's wrong with it. I'm ready to throw in the towel...
What's good: It starts first time every time, and could idle for Australia at 700-800rpm. At low speeds (road and engine) it runs beautifully, smooth as silk although not terribly powerful (it's a stock 998 after all).
What's bad: It'll cruise at 80km/h in top at light throttle just fine, but push harder and the engine develops a stutter which is most obvious in the exhaust note, but the power loss can be felt too. It tops out at about 100-110km/h, and sounds and feels awful with anything more than very light throttle at this speed. Try to go faster and you end up going slower due to the misfire.
I've changed just about everything I can think of in pursuit of this problem:
- New Bosch GT40 coil
- New points, set to .016"
- New condensor
- New dizzy cap
- Centrifugal advance lubed and moving freely
- No runout in the dizzy shaft that I can see or feel
- Known good set of plug leads and plugs, gapped at .030"
- Rocker clearances set at I think .014"
- Fully rebuilt HS4 carb -- new float valve & needle, new .090" jet, new ADF needle, new butterfly disc and shaft, new gaskets throughout, unknown spring. No vaccuum leaks that I can find.
- Currently running SAE80 gear oil in the dashpot -- I've tried everything, this produces the best results
- Timing set at about 8deg BTDC at 1200RPM
- Idle mixture just showing a hint of yellow at 1200RPM by the colourtune
[edit] - New fuel filter
- Brand-new-looking air filter
I'll be buggered if I know what else to check. Currently I'm thinking perhaps there's an obstruction in the exhaust somewhere -- I'm wondering whether some f***wit has had his fun with a can of expandafoam as I can only get 13L into the 27L fuel tank when dry, and if this is the case I wouldn't be surprised to find the muffler full too.
Any other suggestions? Otherwise my next move will be a trip to Minitopia after payday...
