It is currently Fri Jul 18, 2025 9:40 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 25, 2005 4:23 pm
CLUBMAN wrote:
if the gearstick is floppy when its full size,it is eaven worse when you cut it down,i myself dont like it only because iv seen the light for remote change.
Wrong way round I think bu that me..
While we are on it....with the remote's I have two differnt sticks..One is bent and the other is straight..I believe one is a S stick...which one
PostPosted: Fri Feb 25, 2005 8:33 pm
MK2 S and Mini K were bent, black.
MK1 S and Mini Deluxe were straight, chromed.
997-998 Cooper were straight, black. I think.. :roll:
PostPosted: Sat Feb 26, 2005 7:29 pm
resident alien
resident alien
Is this one cut?
PostPosted: Sat Feb 26, 2005 10:12 pm
CHeers Dr.. 8)
and Yes marvin
PostPosted: Sun Feb 27, 2005 11:51 pm
I wanted to do this too. Can I just cut it off and then have to re-thread the gear stick end? Can it be re-threaded in the car or does it need to be removed to re-thread? Im sure I can borrow the threading thingy ;)
Mines a rod change 78 clubman
www.crazybitchracing.com
PostPosted: Mon Feb 28, 2005 6:07 am
Easiest to take it out of the car. Just undo the cup thingy at base of gearstick.
You will probably need to machine the end of the stick back down to 3/8"? before cutting the thread. Or, find a bolt the right size, weld it on and dress the weld.
Another way (better) is cut it a bit lower down, take 2" or whatever out and reweld the top threaded part back on. Done properly, it will look mint. :wink:
PostPosted: Mon Feb 28, 2005 1:01 pm
resident alien
resident alien
My gearknob has a sleeve inside it which slides over the gearstick and the knob has 3 grub screws to hold it on.
Users browsing this forum: No registered users and 23 guests
