It is currently Sat Aug 09, 2025 8:16 am
 Post subject: after market seatbelts.
PostPosted: Sat May 09, 2009 4:07 am
any one got any photo's of what they have & how it looks installed?
how it is bolted up.
wanna see who you guys did it & what neat looking set ups are going around?
ive got some after market ones & i reckon them kipin retractable ones stick out lick dogs balls.
thanks.
PostPosted: Sat May 09, 2009 9:06 am
I run 2 Klippan retractibles in the front of my `70 Matic.
To let them clear the door pockets I redrilled their bolt hole up closer to the reel, then cut the excess off the bracket.
PostPosted: Sat May 09, 2009 9:33 am
great doc great!!
yeh where it bolts to the originally with this seat belts just is to close to me?
it looks messy & it's fouling a tad on the seats.
but with your set up moving it would be a treat!
did you make a new hole far from the original bolt?
PostPosted: Sat May 09, 2009 9:55 am
The body mount is the original spot, the captive nut is welded in at the factory.
I just moved the hole in the Klippan reel bracket up, this dropped the reel down a bit. :wink:
PostPosted: Sat May 09, 2009 9:57 am
ah so you re drilled in the bracket where it bolts to the floor?
then just cut the extra fat so to speak.
8) it looks likes it's meant to be in your mini.
PostPosted: Sat May 09, 2009 10:00 am
I like these belts, they do work well. After useing the #&%^**% static belts in the wife's S replica.... :x
Users browsing this forum: Bing [Bot] and 71 guests
