It is currently Tue Jul 22, 2025 3:18 pm
PostPosted: Sun May 10, 2009 10:09 pm
Does any one know how to fit a rotisserie to a late model clubman which does not have the hole thru the boot or behind the speedo?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun May 10, 2009 10:37 pm
Yep, you build one to go through the bottom of the front and rear screen openings.
No, I don't have one but I've seen pics.
PostPosted: Sun May 10, 2009 10:39 pm
This space for rent
Cut a hole, weld it up afterwards. That's what I'll be doing with my van...
PostPosted: Sun May 10, 2009 10:41 pm
This space for rent
Spinning that one on the spit would be a challenge, all the weight at the bottom :)
PostPosted: Sun May 10, 2009 10:43 pm
Do what Greg (low'n'blown) does..... push the car onto a couple of tyres on it's side.
Can you say....`counterweight??'
8)
You would want a plate with 8 holes and a pin or bolt, so you can stop it at say 45° intervals.
<edit> like this-
PostPosted: Sun May 10, 2009 11:05 pm
This space for rent
<edit> like this-
Ahem.. here's one I prepared earlier :D :lol:
PostPosted: Mon May 11, 2009 7:41 am
sgc wrote:
<edit> like this-
Not mine- I just borrowed it, it belongs to my local vet.
PostPosted: Mon May 11, 2009 8:32 am
This space for rent
:shock: :shock:
I suppose you're going to tell me this is how he services horses :lol:
PostPosted: Mon May 11, 2009 11:32 am
Brackets on each end of the car to hold the spit bar, attach the brackets to the shock mounts on either end, there nice and solid. Someone on here has posted pics before.
PostPosted: Mon May 11, 2009 11:33 am
I have one at home that I can take pics of to show you. It has two bars which are bolted onto the car on the engine bay and inside the boot. uses the subframe mounts. Then these poles go into the stands.
PostPosted: Mon May 11, 2009 11:43 am
thanks I would like to see photos if possible. I had thought about two bars, 1 bolting to the front towers mounts and the other to the rear shock absorber points. I would assume it would need to be reasonable strong and firmly bolted otherwise it may end up distorting the body mounting points as the body would be providing the support and strength in place of the full length pole.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon May 11, 2009 2:33 pm
Pics of the vet's one in here.
It's for earlier Minis but just move the pole up, and add a counterweight...
It all comes apart, I carried it home in an EA sedan.
http://home.exetel.com.au/zoomini/zoomini/850%20pics/
PostPosted: Mon May 11, 2009 3:11 pm
Thanks. Looks like I have another little project to build some thing to suit a late model clubman. Other option may be to push the body onto some old tyres. But this is not a flexible as the rotisserie.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon May 11, 2009 5:14 pm
I can lend you mine if you like how it looks in the pics. WIll post pics up tonight if its not raining. It has the two stands which you use for the 'rotissery' bit, the poles you connect to the car, then it has wheels which you connect to the car as well. Only issues with it being
1. One of the welds is half broke... doesnt mean anything, but if you want to borrow it, I will ask if you can reweld it for me
2. The wheels need oil... but I can do that.
3. Its needs a clean...
Oh and I dont need it for a while so you can borrow it pretty much indefinitely if you want.
Users browsing this forum: Barkfast and 79 guests
