It is currently Mon Jul 28, 2025 1:07 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon May 11, 2009 5:08 pm
meeni wrote:
blue_deluxe wrote:
correct me if im wrong,
But doesnt a hans device only limit the distance your head can go forward and backward? so without one your neck would be thrown forward to your chest with inertia, causing damage to your neck. But the hans device would transfer the inertia through your shoulders and onto your harness. So the deceleration of the car would have to be pretty huge, as in massive impact to a wall, for it to work at its best.
thats right, but most cars (even the mighty supersprint ones) are capable of hitting walls at over 100 kmh which would slow you down pretty quickly and would hurt a fair bit id say
The HANS is to protect you from a 300kph crash. (Like NASCAR or IRL on an oval.) If you want to run one in your VW that is OK with me but don't try to enforce silly rules on everyone when the science does not agree with it.
PostPosted: Mon May 11, 2009 5:15 pm
My arguement is mostly about having this age rule comparable to what the event is.
A lap/sash belt is all that is required for a speed event (autocross for eg) so why should the same age rule apply to a much safer belt when all they're going to do with lap/sash is check for freying. The belt I have is in perfect as new condition, it's just that it's old. Sure have an age restriction for events where a 3 or 4 point harness is minimum requirement, but not when the min requirement is just any old lap/sash that isn't dammaged.
