It is currently Fri Jul 25, 2025 6:24 pm
 Post subject: Electric Aerial.
PostPosted: Tue May 12, 2009 10:02 am
i did a search but nothing come up.
is there any that fit?
maybe of a small jap car?
or any one i can buy from super cheap?
anyone done this?
thanks guys :)
PostPosted: Tue May 12, 2009 10:08 am
I was looking at this late last year.
I bought an electric aerial from Super Cheap. The problem is every aerial I looked at was too long and would've fouled on the tyre.
So I chopped it down a bit which meant there would be about 8cms protruding even when the aerial was fully retracted.
I never did get around to fitting it but that's all I could see to do with what was available.
PostPosted: Tue May 12, 2009 10:15 am
yeh mate. that's what i thought it would foul on the tyre!!
i reckon some one has done it for sure!
PostPosted: Tue May 12, 2009 11:10 am
anyone done this?
thanks guys :)
OMG! You made a post without saying 1275 rover engined van with AC and twin carbies! :lol:
PostPosted: Tue May 12, 2009 11:48 am
haha! :roll: you got me. Anyways if you mount them on a angle they fit so im told.
PostPosted: Tue May 12, 2009 11:49 am
Just put a shark fin style one on. Not going to break down or get broken that way.
PostPosted: Tue May 12, 2009 11:59 am
i need one for the front guard. Them shark style ones are for centre roof mount right? Do you have a link to one so i can look at it? Ebay?
PostPosted: Tue May 12, 2009 2:07 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
I got one from supercheap , it fits OK, doesn't hit anything. I did have to take the first one back it broke after about three goes but they replaced it ,no questions even offered my money back. The second one has been in the car for about four months and is still working.Goes up when the radio is turned on and down when off or CD playing.
https://t.me/pump_upp
PostPosted: Tue May 12, 2009 2:21 pm
can you show me a photo???
i think I've worked I'm stuffed!
there is no original hole for a radio aerial! as it is 64 model.
the only hole on the left hand passenger side originally had a mirror in there? i think!
so I'm not sure what i cant fit as it is sitting above the wheel?
i want to fit some thing there but what how :(
i don't want to drill any new holes & muck around with the paint job as it is awesome as is.
so I'm pretty confused what to buy now.
dam crap mini!
PostPosted: Tue May 12, 2009 2:41 pm
You could always put shark fins on the front guards :roll: :shock: :roll:
PostPosted: Tue May 12, 2009 2:47 pm
would that work? or fit.
your guard is rounded thats flat right? could be a cool :lol:
PostPosted: Tue May 12, 2009 4:23 pm
If you don't do much country driving than maybe consider an internal antena that fits inside the rear window. The one I've used for 5 years is a little box (like a magnetic spare key box) that sticks to the rear window with a flat 6 inch wire sticking out each end. I've also seen ones that are just two wires about 400mm long each that you can run around the edge of the front or rear glass.
No body modifications required. Just mount it away from other electrical items like electric fuel pumps to cut down on interference.
PostPosted: Tue May 12, 2009 7:03 pm
My yellow clubbie has one mounted and no problems with regards to fouling anywhere. Unfortunately, no pics of the car with aerial extended.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Tue May 12, 2009 7:26 pm
I'd go the internal one that sticks to the inside of the window. No holes to be drilled. Perfect!
I used to have a carphone antenna like that. It worked fine.
Users browsing this forum: Bing [Bot] and 73 guests
