It is currently Mon Jul 21, 2025 11:51 am
PostPosted: Tue May 12, 2009 10:22 pm
Hey guys. I'm looking to do the timing on the 77 clubman S. i cant find the timing light>>> anyone know the location???
PostPosted: Tue May 12, 2009 10:25 pm
There is a pointer in the clutch housing (behind that little cover) and marks on the flywheel.
Later motors also had a notch on the crank pulley and marks on the timing cover.
PostPosted: Tue May 12, 2009 10:28 pm
if you cant see the numbers you can make it out by the triangle of the diaphram if you know what your looking for.
PostPosted: Tue May 12, 2009 10:31 pm
This space for rent
The flywheel is often rusty and when moving, the marks can be next to impossible to see. What I do is get the engine to TDC on #1 cylinder so you can see the marks through the hole in the clutch cover, then put a dot over them with some liquid paper. Makes 'em stand out like dogs balls 8)
PostPosted: Wed May 13, 2009 12:19 am
thanks a lot guys for the Quick replies :) Will try it tomorrow.
